Old June 5, 2008, 05:46 PM
Default One of my HDDs broke
I run two hdds in RAID0. one of my hard drives is experiencing a SMART error (bad enough that it won't boot)
I have no real interest in getting my data back (nothing irreplaceable, or even worthwhile). The problem is that I can't tell which one is dead (I wrote it down, on the computer that died).
I want to identify the dead one so that while I'm RMAing, I can just run on the other HDD (I'll install the new one without RAID when it comes)
Any ideas?
Asus p5K-E Wifi/AP / Intel Core 2 Duo e8400 / 2GB Crucial BallistiX DDR2 1066 / eVGA 8800 GTS 512mb / Arctic Cooling Freezer Pro 7 / Razer Barracuda audio / Seageate Barracuda 7200.11 500GB / PC Power&Cooling Silencer 750w
Old June 5, 2008, 05:52 PM
Supergrover's Avatar
Hook up 1 drive at a time, the one that wont format will be the fubared unit.
R.I.P.
Old June 5, 2008, 07:11 PM
ebdoradz's Avatar
you would need to break the raid array be4, otherwise just use killdisk (this application will write zero's all over the dick and break the raid array)
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 5112mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Old June 6, 2008, 07:41 AM
bushwhacker's Avatar
use the manufacturer's Diagnostic Utilities to verify HDD status. This is also an easy way to get RMA approved.
Old June 6, 2008, 04:31 PM
MacJunky's Avatar
*hands out crotch protection devices*
