Old December 13, 2017, 02:31 PM
Default What HDD for gaming build?
Needs to be 2tb or 4tb and 7200rpm, looking at WD blacks or a barracuda Pro? I've been out of the Hard drive world a while since my last drive was a trusty Samsung! Also had a look at the HGST drives but there are a overwhelming amount of drives available.
Any advice and suggestions would be great!
Old December 13, 2017, 02:39 PM
MARSTG's Avatar
If gaming, the Seagate hybrid, the Firecuda, fastest HDD in the 7200 RPM class. Also, has 5 year warranty, like the blacks.
Old December 13, 2017, 06:32 PM
How are Seagate for reliability though, I heard some bad press on them or was that only the 3tb drives?
Old December 13, 2017, 08:52 PM
I have had a seagate hybrid for years now, still shows perfect health. Great drives. I put a second one in my HTPC last spring.
Old December 13, 2017, 09:42 PM
Shadowmeph's Avatar
I have had my seagate hybrid drive for a few years bought one just after a review from HWC I use a SSD for OS and install games on Hybrid drive
Old December 14, 2017, 07:51 AM
I think I might give it a try over the WD Black then. Reviews had me worried but then again people are more incline to write a bad review than praise something for being reliable after a several months/years.
Old December 14, 2017, 05:27 PM
http://www.hardwarecanucks.com/forum...-review-9.html
The 6TB Black is about as good as it gets for HDD but the general Seagate / Toshiba 3TB 7200rpm still overtake the lesser 2TB / 4TB WD Black drives.
Gaming FX 8350 4.4GHZ / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use FX8350 Stock GHZ/GA 970 Gaming/ Rx 580 8GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old December 15, 2017, 05:43 AM
MARSTG's Avatar
Any HDD can fail, if you are that worried you should buy a pair, and keep them in raid 1.
Old December 15, 2017, 01:34 PM
Absolutely agree with you but I think Seagate got bad rep because of those dodgy 1.5/3tb drives a while ago. I'm unfortunately limited to one main drive since it's a mITX build
Old December 15, 2017, 11:16 PM
MARSTG's Avatar
You can have one internal and one external and you can synch them daily with FreeFylesync.
First pc build, part list opinions and questions for 1440p gaming build jerryaire New Builds 3 October 15, 2015 08:44 AM
New Gaming Build. Serilicius New Builds 19 November 18, 2011 10:54 AM
AMD Gaming Build DragonFlame New Builds 13 February 23, 2009 08:33 PM
First gaming build! FantasyBlossom New Builds 31 June 29, 2008 02:01 PM
