Old April 20, 2017, 03:46 PM
TTC TTC is offline
Default issues with vanishign hard drives
So for some reason hard drives keep vanishing once and a while and the only fix is to move from an sata6 port to sata 3. This has happened 3x on 3 different asus boards. Is this a problem with the board?
Old April 20, 2017, 07:57 PM
Bad cable?
Old April 21, 2017, 05:24 AM
TTC TTC is offline
Naw tried a bunch of em.
Old April 21, 2017, 06:09 AM
gingerbee's Avatar
bad drive then. you say it keeps happening with other motherboards too so i would go with drive. if your using different drives then i would say psu my 2 cents
Old April 21, 2017, 09:32 AM
TTC TTC is offline
Yeah, I have a new drive on the way. Lets see what happens. These seagates are utter garbage. Ive killed 3.
Old April 21, 2017, 09:36 AM
Bartacus's Avatar
TTC: did you take a close look at the SATA connector on the drive? I wonder if something is loose or cracked there, so maybe a SATA cable just needs to be pulled to one side for it to lose contact. Also, what about SATA power? When the drive vanishes, did you ever put your hand on it to feel if it still had power?
Old April 21, 2017, 12:32 PM
gingerbee's Avatar
wow that's bad luck 3 dead, hell all I buy are Seagate only had one fail on me personally in 10 years
Old April 25, 2017, 01:46 PM
TTC TTC is offline
Turned out this drives fine .... It was an issue with the asemedia ports.
Old April 25, 2017, 03:33 PM
Sagath's Avatar
So all three boards had bad Asemedia ports? Or is it a compatibility issue with seagate drives and the chipset?
Old April 25, 2017, 07:26 PM
TTC TTC is offline
I'm thinking compatibility issue maybe. One did die for sure, it clicks like crazy.
[WTB] WTB Hard Drives Hard Drives Hard Drives igot6strings Buy/Sell & Trade 5 July 19, 2012 05:37 AM
[WTB] 4x 1TB hard drives werth Buy/Sell & Trade 6 February 25, 2009 07:37 AM
[WTB] hard drives mo' power Buy/Sell & Trade 0 January 28, 2009 10:31 AM
