Old May 18, 2008, 08:48 PM
belgolas's Avatar
Default Good cheap external hard drive.
I am looking for a good cheap external hard drive that can run off of e-sata. So what are some of the cheapest/best. i.e. the best bang for your buck under $200.
i7 2600K 4.6ghz, Asus P8Z68-V Pro 4 x 2 gigs of DDR3 1600 mhz, 160GB Intel SSD, 2TB black, 2TB back-up, 2TB media drive, 18x DVD burner, EVGA SLI GTX 480 SC (water cooled), G15 and G9 keyboard and Mouse, Alienware Optx 3D monitor, Corsair 1000w. Asus Xense, Corsair 800D.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old May 18, 2008, 08:54 PM
sswilson's Avatar
Is there a reason why you don't want just an enclosure that you can slap your choice of HDD into?
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old May 18, 2008, 09:06 PM
belgolas's Avatar
That would work too.
Sponsor a child!
Fight poverty.
Qoute by Perineum
Old May 18, 2008, 09:58 PM
belgolas's Avatar
I think I might get this one. It looks nice and esata is nice to have.
oooppps forgot to add link
http://www.ncix.com/products/index.php?sku=28367
Sponsor a child!
Fight poverty.
Qoute by Perineum
Old May 19, 2008, 07:21 AM
Nodscene's Avatar
Yeah, for the price you can't really go wrong with the Vantec's. I've never had one long term but during the time I've used them I didn't really experience any problems.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old May 19, 2008, 11:09 AM
bobletman's Avatar
Seagate has some really cheap harddrives and then you can also buy a cheap harddrive enclosure and bam you have a really cheap removable harddrive.
Q6600 Core 2 quad @ 3.0Ghz
2gb of patriot ram reduced latency.
500GB 7200 rpm Seagate (baracuda)
BFG nvidia 8800 GTS 512 MB G92 core
Zalman CNPS9700 LED CPU fan
Ultra X-Blaster computer case
P5K-E Wifi edition MOBO
G15 keyboard and G7 mouse
22 inch widescreen samsung
Z5300e speaker system
3Dmark06 score 15K
Old May 19, 2008, 11:10 AM
Supergrover's Avatar
Thats what I would do.
I'd grab that vantec and a 500g hdd.
My 0.02.
R.I.P.
Old May 19, 2008, 12:38 PM
Jack Rabbit's Avatar
If you plan to carry this around a lot I would suggest going for one of the laptop drive models that runs solely off USB power. I had to carry one of these around for work and it was more of a nuisance than I thought it would be and the cables were the worst part. Think about buying 2 and sacrificing one of the enclosures for portability. Leave one set of cables permanently connected to your main PC/power and put the other set in your carry bag. This way you only need to unplug and go.
I doubt you can really go wrong with these things. My colleagues and I used several dirt cheap ones and never had a problem with stability or compatibility.
- James Graham
Old May 20, 2008, 10:44 PM
Dashock's Avatar
Belgolas take a look in the storage area i did a review on that exact enclosure to see what your getting into if you can live with the negatives go for it!
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
Old May 20, 2008, 10:48 PM
Dashock's Avatar
If your only going to be usiing it for short durations its finee and its all aboot the hard drive u use do not and i mean do not use the 7200.10 model segates they just run wayy too hot in that case after an hour. The new 7200.11 should work better but if your going to be using it for long durations i suggest looking into the Antec one that comes with a fan its a little more pricer at around 55 bucks but itll keep the hard drive cool my 2 cents.
Asus P5Q-E
Antec Spot Cool
Logitech X-230
