Old March 24, 2016, 02:30 PM
Caldezar's Avatar
Default How to clone to a smaller destination drive?
I recently picked up an SSD to upgrade a PC. The original OS HDD is 1TB, but only about 350GB is being used. I want to image the drive over to the SSD, but the destination SSD is only 500GB. But any imaging software I've ever used will only allow cloning to an equal or larger destination drive. Does anyone know an easy way to accomplish this? Is there any decent freeware that will allow me to shrink the volume and only clone the volume? Or some other option that will work?
Old March 24, 2016, 02:48 PM
SugarJ's Avatar
Which SSD? A lot of them have software available that will clone the drive for you and ignore the difference in partition sizes. Intel and Corsair both do, I've used them.
Edit: Also, the windows partition manager can shrink partitions as long as the data doesn't go past the partition. Defrag first.
Old March 24, 2016, 03:12 PM
Samsung Data Migration if going to a Samsung drive.
Easeus Todo Backup Free is another nice one.
heatware
Old March 24, 2016, 03:36 PM
JD JD is offline
I used that today actually. This was for a laptop, so I pulled the drive and plugged it into another PC along with the new SSD.
It mostly worked, but it didn't create the proper boot manager/files. I had to run the Windows Setup repair and a bunch of bootrec commands.
Old March 24, 2016, 05:12 PM
yamawho's Avatar
Just wondering if the eMMC drives on these mini pc's can be imaged ...
Anyone try this ?
Old March 24, 2016, 07:44 PM
Perineum's Avatar
I've done it lots of times. Uninstall everything that isn't needed, etc. Defrag the drive, then use Windows storage manager and shrink the partition. Once the size is less than the size of the SSD it should just work.
Old March 24, 2016, 08:38 PM
Lpfan4ever's Avatar
Easeus Todo Backup and Macrium Reflect are my go-to for this sorta stuff. Macrium did my last migration, albeit from smaller to larger.
Originally Posted by encorp
Code:
<firebane> slightly used
Old March 24, 2016, 09:10 PM
Look into using Clonezilla with the -k option.
Old March 25, 2016, 07:28 AM
ipaine's Avatar
Acronis works for this and I have used it on numerous occasions.
Even the free version that comes with the Crucial drives works as well.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old March 25, 2016, 07:38 AM
Caldezar's Avatar
Destination is Samsung.
Thanks for the responses gang! I've got a couple options to try at my fingertips now.
Clone SSD onto another SSD? geokilla Storage 3 May 22, 2013 05:37 PM
How do you clone a drive easily? bonanza2000 Storage 13 January 11, 2013 06:03 PM
want to switch out a 60GB SSD for a 120gb SSD do I clone the Drive? Shadowmeph O/S's, Drivers & General Software 1 October 3, 2012 01:19 PM
How to Clone Dell's Recovery Partition to Another Drive yustas Storage 2 February 16, 2010 08:17 PM
Best Vacation Destination JD Off Topic 15 April 5, 2009 06:10 AM
