Old October 20, 2014, 09:51 AM
ipaine's Avatar
Default What SSD to switch to?
Ok, so I am looking for some input on what drive I should move to for the ssd in our builds at work. We currently have been using the Intel 530 240GB for some time and were using the 520 series before that.
I have been noticing that stock levels for the 530's are getting lower and they are harder to find in stock, so we want to find a possible drive to move to.
The replacement drive has to be at least about the same performance, we don't want any major drops in performance. Basically something in the 240-256GB range for around the same price $150-180. Warranty and longevity are important on these. Also no OCZ drives, yes I know they are completely different from before but we got burned bad on the vertex 2 drives so I doubt I could convince people to go back to them. I know I like the Samsung's but the warranty in Canada has me worried to go that route. I did look at the Intel 730 series but at the 240GB size the write speed is way slower and the drive costs more.
So any suggestions as to what to go with? Ideally something that people think will stick around for a bit like the 520/530 series has.
Thanks
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old October 20, 2014, 10:13 AM
Off the top of my head - Crucial/Micron seems to have 3 year coverage on their drives though that is somewhat less than Intel's 5 on the 530, one of them could be an option. Speeds look reasonable and they make their own NAND, IIRC. Possible issues with service times on the Micron M600 drives though.
Personal Rig: See System Specs
HTPC: Pentium G3420, MSI H81i, 4GB G-Skill DDR3 1333, GeForce 650, 400GB Recertified Seagate, 1TB WD Caviar Green, 750GB WD Caviar Blue 2.5", Cooler Master Elite 120 Advanced, Windows 7 x64, 32" Seiki LCD TV, Panasonic SA-HE75 5.1 Reciever
9x Gamer: eMachines eOne - 433 Mhz Celeron, 64 MB RAM, 8MB ATI Rage XL, 6GB HDD, Windows 98se
9x Gamer #2: 500 Mhz Pentium III, 512MB Ram, nVidia Geforce 5600, 20GB HDD, Windows ME
Old October 20, 2014, 10:23 AM
Yup go with Crucial MX100 - supports encryption and OPAL 2.
RMA with Crucial is very easy though still requires shipping to USA.
Ditched those (relatively) slow and expensive Intel drives some time ago. Glad to be rid of Sandforce.
heatware
Old October 20, 2014, 11:21 AM
Bond007's Avatar
Crucial Mx100 or m550 depending if you want the cheaper price or higher performance.
Desktop: Antec Three Hundred, Z77-D3H, 3570K undervolt @4.1ghz with Zalman Optima Cooler, Corsair Vengeance 2x4gb@1866mhz, HD 6950, Seasonic S12II 500W, WD Black 1TB, Intel 530 120GB
Old October 20, 2014, 11:52 AM
SugarJ's Avatar
Check out the Intel Pro 2500 series. Basically the same as the 530, but meant for business customers which means they should have a longer shelf life. Pricing looks to be similar to the 530.
POE Switch? bastone7 Networking 7 March 19, 2014 01:06 AM
Corsair K95 Brown switch 104 and white switch micro key lemoncall Peripherals 6 November 30, 2013 10:22 PM
need a kvm switch rob123 Peripherals 4 June 22, 2012 04:25 AM
How switch HDD to SSD Kilauea Mobile Computing 17 June 10, 2011 02:09 PM
My Switch Mod kcksteve Networking 0 September 24, 2007 04:25 PM
