Old May 8, 2014, 09:25 PM
Default Advanced format on old RAID card
I'm debating if I should upgrade my RAID card since it does not support 4K format. While WD's Advanced Format states it has 512 emulation, I'm not sure if it will work on a RAID card.
Old May 9, 2014, 05:31 AM
misterd's Avatar
What RAID card are you using now? I'm in the same boat with my PERC5i, but i'm probably going to bite the bullet and keep that going for a backup array.
#hardwarecanucks on irc.freenode.net
fiat justitia ruat caelum
Old May 9, 2014, 05:50 AM
MARSTG's Avatar
I think the 4K format needs to be supported by the drive first of all and has nothing to do with the controller, as the size of the block in the array it is defined in the menu of the controller card.
Old May 9, 2014, 09:35 PM
Well I have an old 3Ware 9400S-12 (PCI-X) that I'm considering using with WD 2TB Red which is Advanced Format. I'm also debating if I should just buy a 5i off someone here and use that. Why are you considering trading in a 5i, misterd?
Need some serious RAID card help.. implosion222 Storage 33 March 31, 2014 08:03 PM
Raid card doup93 Storage 4 January 31, 2013 02:25 PM
Format RAID 10 HDDs if want to add 2 more HDDs? hedgehog88 Troubleshooting 1 June 16, 2012 06:17 PM
RAID Card - Yes, No, Maybe? AmuseMe Storage 12 December 17, 2009 07:25 PM
do I need raid card? bumfloss Storage 11 June 27, 2009 05:14 PM
