Old April 29, 2014, 06:37 PM
Default Supermicro SAS controller help.
So I got the supermicro AOC-SAS2LP-MV8 card to add a few drives in my tower. Put the card in a PCI-e slot. boot the computer , bios splash screen comes up then nothing. There's a blinking line on the top left corner of the screen and that's it. System hangs there. can't boot into the O/S at all. I have the latest firmware for the bios installed as well. Tried all PCI-e slots with no success either . Anyone have an idea ?
Much thanks
Gaming Rig
Core i7 7700k 4.7ghz
EVGA GTX 1080ti 11Gb SC
Asus PG348Q + Dell U3415W
Asus Z270 Prime
16GB DDR4 Corsair Vengeance 3200 mhz
Samsung 850 Pro 500gb
Samsung 840 pro 256gb x 2
Crucial 500 GB SSD
Corsair HSX 1000watts
Corsair Obsidian 750D
Razer Deathadder Chroma 2016
Logitech G710 +
Asus Xonar Essence STX
Sennheisers PC360
Old April 29, 2014, 06:50 PM
BlueByte's Avatar
Write supermicro about motherboard/chipset support.
You may have to lose your UEFI to get the RAID card to work. <-- most likely
Play with slots to see if that makes a difference.
Boot with no drives on the card to see if it boots into the OS.
Thats it off the top of my head.
Old April 30, 2014, 08:51 AM
wouldnt disabling the UEFI screw up my boot sequence and potentially have to rebuild my o/s from the ground up tho ?
I've tried all the slots already with no luck. Also booted with no drives attached to the card.
Gaming Rig
Asus Z270 Prime
Crucial 500 GB SSD
Logitech G710 +
Sennheisers PC360
Old April 30, 2014, 03:26 PM
found the spec page for the card on their site, they seem to have a new firmware version listed in the FTP link from Jan 2014. Have you thought of updating the firmware at all with the card in another system to see if that resolves it? they may have caught this already?
Product page
Supermicro | Products | Accessories | Add-on Cards | AOC-SAS2LP-MV8
FTP link to firmware
ftp://ftp.supermicro.com/driver/SAS/...re/4.0.0.1812/
I'm having difficulty locating any release notes on that firmware version though
they do have this controller listed as an optional part for this server which apparently has uefi support, so there should be a means of getting it to work, assuming this is an issue with uefi compatibility
Supermicro | Products | SuperServers | 2U | 6027R-WRF
Old April 30, 2014, 06:58 PM
BlueByte's Avatar
Product page
Doh I forgot step 1!!! always upgrade firmware. If you are worried about having to rebuild your OS create a live boot on a USB key or CD just to see if it makes a difference. Was the card new or used? Still under warranty if used? Supermicro may have a unreleased beta firmware for you to try as well, if you contact them.
Old May 1, 2014, 06:28 AM
Hey guys, Thanks for the help . The card is brand new from newegg.ca . I contacted supermicro and they they haven't sent me anything back yet. I popped the card on my Z-87 with the same results.
Maybe I'll try to flash the card.. although I can't even access the motherboards bios as it is so that might be tricky. I might just request an RMA from newegg and a refund :/
Gaming Rig
Asus Z270 Prime
Crucial 500 GB SSD
Logitech G710 +
Sennheisers PC360
Supermicro SC846 FreeNAS Server Build zoob Case Mods, Worklog & Gallery 52 July 2, 2017 06:31 PM
Anyone ran a Supermicro H8QGI-F? tray HardwareCanucks F@H Team 8 April 4, 2013 04:29 PM
[FS] Supermicro opteron 4p servers jtktam Buy/Sell & Trade 13 April 5, 2012 02:37 PM
Supermicro 3U cases jtktam HardwareCanucks F@H Team 22 January 15, 2012 03:32 PM
Supermicro X7DVL-E in a regular ATX case elec999 CPU's and Motherboards 0 November 17, 2008 11:27 AM
