Old May 6, 2008, 02:31 PM
Default Still no HD
Thanks for all the replies guys.
1) I tried the Fix NTLDR disk from tinyempire's (Simple "ntldr is missing" fix with boot floppy, CD-R, or USB flash) site but none of the ten fixes worked. I haven't tried his other suggestions.
2) I have moved the HD to a new computer but now the HD appears on BIOS but I cannot access it in any way.
3) Can I use a DOS disk and try a:/fdisk/mbr?
4) tzetsin, could you give me some detailed instructions or a link. I am not very familiar with DOS but can follow along.
Windows XP Pro * Intel E4500 * GA-P35-DS3L * 2G-OCZ P800 PC6400 * eVGA Geforce 8500GT * OCZ Stealth Extreme 600w * Coolermaster 900
Old May 6, 2008, 05:49 PM
BrainEater's Avatar
Um....
There's another thing that will cause a 'NTLDR is missing' error.I'm surprised no one mentioned this.
Are you sure it's set to boot from the right HDD in bios ?
Supermicro X11DPi-NT:2x Xeon Gold 6144's:Lots more other stuff.Dual 4k monitor video .
Old May 6, 2008, 05:55 PM
Originally Posted by BrainEater View Post
Um....
That very very very seldomly is the case.
The problem is that hdd has become damaged in some way and broke the windows install.
All you need to do is boot into the recovery console using your XP cd
and do this..
Code:
COPY CDDrive:\I386\NTLDR C:\
COPY CDDrive:\I386|NTDETECT.COM C:\
chkdsk /r
Old May 6, 2008, 06:48 PM
BrainEater's Avatar
Heh
So say you.
I went through that exact problem about 20 times during the endlife of my striker.The bios reset allatime , and hence the boot order did.
