Old April 6, 2014, 08:46 PM
Evylldemon's Avatar
Default No more SATA ports
So I guess I wasn't thinking far enough ahead when I bought my motherboard but I ran out of SATA ports (this is the board I have: ASRock FM2A75M-ITX). If it matters, the motherboard has a PCI Express 2.0 x16 slot which is not being used.
I want to add another hard-drive but I can't without removing something. Is there any way to expand the number of SATA ports? I have looking at one of these PCI cards: Syba SI-PEX40057 but it doesn't appear that it would fit and I'm not sure it does what I want anyway.
Hopefully I'm not out of luck here...
Old April 6, 2014, 08:54 PM
Shadowmeph's Avatar
You could get one of those cards or use larger harddrives
Old April 6, 2014, 09:16 PM
Evylldemon's Avatar
I was hoping to just add a 4TB drive rather than replace my existing 3TB drives.
If there card does the trick I'll just get one of those. Will a PCIe x2 fit into a PCIe x16 slot?
EDIT: the Google-machine tells me yes.
Old April 6, 2014, 10:02 PM
Shadowarez's Avatar
Yes it will fit some ppl had to put those asus raidr cards in diff pci slots just to make Em work. You can put pci-e 1x 2x 4x 8x into pci-e 26 slots.
Old April 7, 2014, 07:33 AM
Birk's Avatar
Do you have a Sata Optical Drive plugged in?
If so ditch that and get an external USB optical drive.
Old April 7, 2014, 07:59 AM
Arinoth's Avatar
Are you currently using that PCI-E slot for anything or is it just left 'bare'/empty. IF so then that would be a viable option.
You could also get (I don't have the time to look it up but I know they exist) USB 3.0/2.0 to SATA adapter as well, provided you get one that just plugs into one of your motherboard's usb header slots (for best results use USB 3.0)
Here I am: here I remain
Old April 7, 2014, 08:38 AM
It bothers me that nowhere does it state it can run drives in JBOD or a "non-raid" config. It only only refers to RAID configurations. You may not be able to just plug and play new drives in without configuring a raid setup, which is clearly not something you are looking to do.
Problem with asus rampage 3 extreme sata 3 ports Fro Troubleshooting 3 October 29, 2011 08:20 PM
question on SATA ports on P8P67 B3 cmge CPU's and Motherboards 6 August 10, 2011 06:27 PM
ASRock P55 Extreme4 Brings Four SATA III and USB 3.0 Ports FiXT Press Releases & Tech News 5 July 8, 2010 02:07 PM
Setting up Raid.. Does it matter what sata ports I use? Yamcha Troubleshooting 9 February 1, 2010 08:17 AM
[FS] WTT/WTS DVD's for cash/sata optical drive/sata hdd's/ Geforce 9800 or better The MAX Buy/Sell & Trade 4 April 16, 2009 04:22 PM
