Old March 29, 2014, 03:39 PM
Default Need some serious RAID card help..
I just installed an LSI megaraid 9040 i4 card in my system.
Specs : Asus P5N32-E Sli board
Windows 7x86
Put the card in on a PCI-e 16x slot and I keep getting this : no physical memory is available at the location required.
Anyone know what I could do ? I tried different PCI slots with no effects. Tried booting with 1 stick of ram, no effects. Ran Memtest86 on the Ram, no issues detected. The system boots in windows when the PCI slot is not populated with the Raid card.
Gaming Rig
Core i7 7700k 4.7ghz
EVGA GTX 1080ti 11Gb SC
Asus PG348Q + Dell U3415W
Asus Z270 Prime
16GB DDR4 Corsair Vengeance 3200 mhz
Samsung 850 Pro 500gb
Samsung 840 pro 256gb x 2
Crucial 500 GB SSD
Corsair HSX 1000watts
Corsair Obsidian 750D
Razer Deathadder Chroma 2018
Logitech G710 +
Asus Xonar Essence STX
Sennheisers PC360
Audioengine A2+ Speakers
Old March 29, 2014, 04:03 PM
lowfat's Avatar
So this happens at post? Try disabling onboard devices. Unfortunately it still may not work. Lots of boards and most especially Nvidia boards have issues w/ various raid card and other cards that have bioses that need to load at post.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 29, 2014, 04:20 PM
I disabled all onboard devices ( short of SATA) and no dice.. As soon as it's done going through the LSI bios it goes straight to the physical memory error.
Gaming Rig
Asus Z270 Prime
Crucial 500 GB SSD
Logitech G710 +
Sennheisers PC360
Old March 29, 2014, 05:23 PM
Ok I reset the cmos battery and now I'm able to log into windows. I'm having a hard time figuring out how to install the raid drivers tho
Gaming Rig
Asus Z270 Prime
Crucial 500 GB SSD
Logitech G710 +
Sennheisers PC360
Old March 29, 2014, 05:45 PM
http://i.imgur.com/wajbNub.png
This is what I'm getting right now
Gaming Rig
Asus Z270 Prime
Crucial 500 GB SSD
Logitech G710 +
Sennheisers PC360
Old March 29, 2014, 05:46 PM
command prompt made need elevated privledges to run properly.
Old March 29, 2014, 06:12 PM
I right click on the exe and run it as an administrator..
Gaming Rig
Asus Z270 Prime
Crucial 500 GB SSD
Logitech G710 +
Sennheisers PC360
Old March 29, 2014, 06:15 PM
Try starting a elevated command prompt with admin privledges then run that same command.
I'd suggest placing that directory in the root of C to make it easier.
Old March 29, 2014, 07:07 PM
I started reading on it ... so the WDCFG file has to be dumped in system32 which I have done. Also created an LSI folder. and now I have to install the driver through a command line interface "command prompt"...I am so lost.
Gaming Rig
Asus Z270 Prime
Crucial 500 GB SSD
Logitech G710 +
Sennheisers PC360
Old March 29, 2014, 07:34 PM
Why are you using WDCFG? It's not even the driver itself. From the manual:
Wdcfg provides run-time control over various configuration parameters which configure LSI host storage
drivers used on the Windows operating system.
Wdcfg allows manipulation over a varfiety of driver configuration parameters. Note that some
parameters can have a seriously adverse affect upon system operation if set incorrectly, so the user is
cautioned to exercise care when using WDCFG.
Raid card doup93 Storage 4 January 31, 2013 02:25 PM
RAID Card - Yes, No, Maybe? AmuseMe Storage 12 December 17, 2009 07:25 PM
do I need raid card? bumfloss Storage 11 June 27, 2009 05:14 PM
do i need a raid card for a server. kyle_L Storage 15 April 1, 2009 12:21 PM
looking for a raid card that does 0+1 cujo Storage 0 March 10, 2008 11:14 AM
