  #31 (permalink)
Old March 30, 2014, 10:14 PM
I'll have to get a hold of electrical tape at work tomorrow.. it looks a bit sketchy tho.. If I have to go this far to make a brand new card work.. it may just be worth RMA'ing it and getting something else. I might try it tho. Putting the raid card in the top 16x slot seemed to fix the physical memory issue at least for the moment. Booting takes a very long time still and that's not normal.
Gaming Rig
Core i7 7700k 4.7ghz
EVGA GTX 1080ti 11Gb SC
Asus PG348Q + Dell U3415W
Asus Z270 Prime
16GB DDR4 Corsair Vengeance 3200 mhz
Samsung 850 Pro 500gb
Samsung 840 pro 256gb x 2
Crucial 500 GB SSD
Corsair HSX 1000watts
Corsair Obsidian 750D
Razer Deathadder Chroma 2016
Logitech G710 +
Asus Xonar Essence STX
Sennheisers PC360
  #32 (permalink)
Old March 31, 2014, 05:13 AM
Originally Posted by MAK View Post
I know this may sound totally weird, but have you tried blocking pins B5 and B6 on the card?
If you go to this page (PERC 5/i RAID Card: Tips and Benchmarks), scroll down and read about the SMBus issue with Intel Chipsets.
The moment you said "no physical memory is available at the location required" it rang a bell. I got a dell RAID card (basically an LSI one) that just would not work when plugged into a motherboard. Most of the time it would fail to post (the beeps indicated a memory error).
One of the pins on the PCIe slots (B6?) also seems to control memory. If it gets a conflicting signal, you may get odd memory errors, missing devices and cards that won't initialize.
I would not use nail polish for this (looks like that's what they did in the link above). I used a piece of black electrical tape and the card is working perfectly for me in RAID. Here's a link to what it looks like with tape (SAS HBA crossflashing or flashing to IT mode, Dell Perc H200 and H310 | techmattr) - (just ignore the flashing advice on that page).
Try it. Does it work? I'd love to know. I feel weird having a card that has two pins blocked in the PCIe slot in my server, but it is working...
I had to do the same thing trying to run 2 H310 cards on my H8SGL-F motherboard. It's been running for months now without any issues. Without the tape, the board would not boot at all.
  #33 (permalink)
Old March 31, 2014, 04:12 PM
Well.. I just flashed my bios to the latest version and now the screen doesn't even come on..
Gaming Rig
Asus Z270 Prime
Crucial 500 GB SSD
Logitech G710 +
Sennheisers PC360
  #34 (permalink)
Old March 31, 2014, 08:03 PM
Alright well apparently the gpu I had in there shit the bed ( XFX GT 220 ) replaced it with a gtx460 and its up and running. unfortunately the bios update didn't help anything still getting the same issue. I will RMA the card and look for something else.
Gaming Rig
Asus Z270 Prime
Crucial 500 GB SSD
Logitech G710 +
Sennheisers PC360
Raid card doup93 Storage 4 January 31, 2013 02:25 PM
RAID Card - Yes, No, Maybe? AmuseMe Storage 12 December 17, 2009 07:25 PM
do I need raid card? bumfloss Storage 11 June 27, 2009 05:14 PM
do i need a raid card for a server. kyle_L Storage 15 April 1, 2009 12:21 PM
looking for a raid card that does 0+1 cujo Storage 0 March 10, 2008 11:14 AM
