Old May 2, 2008, 06:03 PM
Nodscene's Avatar
I usually end up with a few partitions, not all that different from everyone else. Except I might have a few more since I like to keep pretty organized.
OS
Data (all my program install files)
Downloads
Music (mp3's and flac)
Photography
Audio (mixing and mastering)
I might have one or two more but since I'm still waiting on my getting my computer together I don't quite remember them all. I think that about covers it.
Old May 2, 2008, 06:26 PM
1Tanker's Avatar
Originally Posted by crazyazn View Post
Wow, didn't really expect this many replies so fast...thanks guys. After reading all the posts, I think I'll have 4 'drives' in total: Windows & Programs, Music, Downloads (temp storage before I sort them), and Data (for Movies, Pictures, Work, etc...). I'm thinking of setting them to be 30G, 80G, 20G, and whatevers left for Data. Does this sound good? Also, I have my Pagefile set to a constant 3072MB (1.5X RAM?). Is that about right?
That's okay, but with 2GB of RAM..you could probably get away with 1024/1024 or 1536/1536. When they first recommended 1.5x RAM, 2GB was unheard of.. and even 1GB. If you're doing a lot of heavy RAM-intensive usage(most notably Photoshop, and some Encoding-type apps).. then more can be better.. but the bigger the page-file, the more fragmented it can get. Sometimes i run with little to no page-file, with no problems(2GB RAM on XP-Pro 32bit). GL
Old May 3, 2008, 05:27 AM
Jack Rabbit's Avatar
Partition sizes depend on what you want to put in them. 80G for music is not going to work if you have 100G of mp3s. I find 30G is good for the OS partition but I do not play a lot of games. Age of Conan will be a 15G install (or more) so you need to inventory what you need to put in there and leave some room for what you will want in the next 6 months. My temp drive on the day-to-day computer is only 9G because stuff does not live there very long. I either use whatever I download (read it, watch it, install it) and delete it or it gets moved to the NAS for long term storage. Keeping it small forces me to be a little more organized.
As 1Tanker noted you do not need a page file that big. I would suggest 2G. Just lock it and forget it. You could optimize the size for your usage but you would have to research it and benchmark it and fiddle around a whole bunch. If you want to do it it will be quite the learning experience but does not sound worth the time investment as you will only see a tiny improvement.
- James Graham
Old May 3, 2008, 02:46 PM
Alright, I'll set my pagefile to a constant 2048MB then. Also, is creating a partition just for games (storing/installing there) advisable? Or should I just install them onto C:? I think these will be my final questions before making the partitions and reinstalling Windows...
Once again, thanks so much for the help guys.
Antec NSK 6500 w/ TriCool intake, S-Flex F exhaust
Corsair HX520
Gigabyte GA-965P-DS3 Rev1.0 @ 500FSB
Intel C2D E6300 @ 3.5ghz 1.45V
Arctic Cooling Freezer 7 Pro
Mushkin (996576) 2X1GB HP2-6400 @ 1000mhz 5-5-5-15 1.9V
eVGA 7600GT KO @ 630/880
Seagate 7200.10 320GB
Samsung SH-162
Samsung 205BW
Logitech Media Keyboard
Logitech MX518
Old May 3, 2008, 06:58 PM
I gave my answer but nobody seemed to care :(
Old May 3, 2008, 07:22 PM
I would love to do things your way...but it cost more and I don't want to spend money on another HD when I still have space. I'm a student and I don't have much money, and I'd rather spend whatever I can use toward a new video card.
Corsair HX520
Samsung SH-162
Samsung 205BW
Logitech MX518
Old May 3, 2008, 08:18 PM
Supergrover's Avatar
No I agree hdd prices are low nowadays and the best choice is simply buy another drive or better yet grab 2 and raid0 them but I figured the OP didn't want to buy another drive.
R.I.P.
Old May 3, 2008, 08:59 PM
Yeah...I don't really want to buy another drive as it's basically guaranteed to cost at least $50 and I'm not hitting the sweet spot...it'd give me a lot of space but I wouldn't know how to organize things...hahah
So now I'm only wondering if I should make a partition specifically for installing and storing games...
Corsair HX520
Samsung SH-162
Samsung 205BW
Logitech MX518
  #19 (permalink)
Old May 3, 2008, 11:21 PM
sswilson's Avatar
I avoid installing any Apps on non-default drives. Maybe the coders are getting better, but I remember all to well the bad-old-days of certain programs behaving quite badly when they couldn't find their config folders where they were used to looking. :)
Putting games on a different partition will certainly speed up doing a daily automated virus check on your boot partition, but aside from that, I'm not sure there's much benefit to it.
  #20 (permalink)
Old May 3, 2008, 11:36 PM
jtdoom's Avatar
Default drives are out. sometimes
I ran striped 300, partitioned as 200/400.
the other raid was striped 250 drives, as 500 (what had a copy of data in the 400.). and I say I was lucky to have had a good backup routine.
The machine fripped, and the best data was on an external 1tera
That was a year ago.
since then I run two 500 mirrored (not partitioned so it is 465 Gb)
one stripe (two 300, total 560 odd) >not same.< (same models I had as the fripped.. I had 12 of those in use.)
and I still backup to my externalS (PLURAL)
Kind regards, Jaak.
