Originally Posted by ChikenKannon I apologize for the lack of information, I'm not really sure what kind of info I should post. |
ooouucchhhhh! sounds like you should be taking it to a shop.
What hardware is first and foremost. In your case, motherboard make & model particularly.
Run
CPU-Z to easily identify it and the BIOS version.
I'm using XP professional, not sure what version or anything more detailed.
Right click 'My Computer', select 'Properties' and read "System" info
Thanks for the quick replies, for more information just ask. And guide me how to get to said information.
You do need to learn some things to be capable of following up and resolving technical issues through forums and/or newsgroups. google is your friend. Accessing the BIOS, for example, and reading the manual for your motherboard might reveal a setting is wrong or you need to flash the BIOS to have it properly identify the HDD.
