Old January 25, 2014, 05:13 PM
Default Raid Card Questions
So I am looking into making a small home server/media server. This will have a pretty low load of maybe 2-3 users at a time, no more. For the most part I will be using it as a media server and also as a network backup location.
I plan to run this in a RAID 5, but I really don't know what raid card to get and I hoping someone here is more knowledgeable about raid cards on the market than I am.
I am looking for a card that has decent performance in raid 5 in the $200-300 range.
Anything you guys recommend?
Old January 25, 2014, 05:34 PM
Perineum's Avatar
The Dell PERC cards... there are some for sale here on this site from a trusted user.
Old January 25, 2014, 05:39 PM
lowfat's Avatar
I'd honestly suggest skipping on a hardware RAID card and use FreeNAS w/ a RAIDZ array. It is a superior solution if you aren't going for outright speed. A gigabit network will still be the bottleneck.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old January 25, 2014, 06:05 PM
I should have mentioned, I plan on using Windows Server 2012 Datacenter on this box (got 2 copies for free for being a comp sci major). I also plan on setting up a domain in the house and this box will also be the domain controller. It will also most likely be running a small teamspeak server too, so FreeNAS doesn't quite have all the capabilities I want.
Old January 25, 2014, 08:03 PM
Shadowarez's Avatar
Iv used and loved the lsi raid controllers that have 1 gb of ddr3 ram. Iv setup raid 5 with them for servers and domain controllers and Ias servers.
Nice cards but lil pricey depending how much ram you need onboard.
Old January 25, 2014, 08:10 PM
JD JD is offline
Since your running Server 2012, you could just use the "storage pools" functionality. It won't offer the greatest performance, but for what your needs are, I don't think that's a huge issue.
Otherwise, just use the onboard RAID assuming you buy a half-decent motherboard.
Old January 27, 2014, 07:43 PM
Since everyone seems to be recommending on board, do you guys think something like THIS would be able to handle raid 5 with decent speeds?
I didn't realize on board raid controllers had come this far. I mean 1 and 0 have always been simple but the last time I saw an onboard raid 5 you were lucky to get 20-30MB/s out of it. For those that have done an onboard raid 5 recently, what kind of speeds are you seeing?
Old January 27, 2014, 08:39 PM
I suggest not using Server 2012's parity Storage pools unless you're clearly only reading from that pool. This link (Why Windows Server 2012 Parity Storage Spaces Might Perform Slowly - Premier Field Engineering - Site Home - TechNet Blogs) documents performance issues when using a parity storage space and having personally tested this using four 7200 RPM drives and getting about 20-25 MB/s, I can only say to NOT use that (Servers home lab).
For low end/light usage, onboard RAID can be fine. Else, a dedicated RAID card is the best bet. As mentioned before, Dell's PERC cards are a good option or you can look for an IBM Serveraid M5015 (used ones can be found for 250-300$ range) which is basically an LSI 9260-8i.
Old January 28, 2014, 06:49 AM
JD JD is offline
I thought Storage Pools were just slow because I was running it on an Atom... guess not
And Intel RAID5 should be good for 50-75MB/s write, at least that's been my experience. Though if you enable write caching, and risk data loss, you should be able to do over 100MB/s which would exceed a single Gigabit link.
Old January 28, 2014, 08:11 AM
Nah, My file server's running an Opteron 6128, 16 GB RAM and H310 RAID cards and I get 20-25 MB/s when using a parity storage space. For OP, enable write cache and use a decent sized UPS connected to your file server and have it shut down automatically if power goes out. That way, you don't loose data but get the performance boost.
motherboard raid questions/ stutter questions HiTi Troubleshooting 5 October 14, 2013 07:40 PM
RAID Questions Patlabor New Builds 5 January 15, 2010 12:14 PM
RAID 1 Questions Kilauea Storage 8 January 8, 2010 06:43 PM
Raid Questions slay3r Storage 34 December 3, 2009 09:50 AM
Raid 0 questions Canzara Storage 3 November 29, 2009 11:51 AM
