Old January 22, 2014, 06:08 PM
sakage.shinga's Avatar
Default Free ISO Burner stopped working after reformat
Hi guys,
My old build used to be able to run Free ISO Burner just fine. However, ever since reformatting, I can no longer select the proper burn speed and leaving it on MAX results in a burn error (hardware error 14848). It is the same LG blu-ray/DVD-burner combo drive and nothing has been changed with the exception of me removing the sound card.
I've tried uninstalling/reinstalling the drive, plus redownloading the burner software.
Does anyone know what's going on?
EDIT: I tried Active ISO Burner instead and it works like a charm! Anyone know why Free ISO Burner is suddenly broken after a reformat?
Thanks!
Photography/Gaming build: i7-4770K, NH-D14, Z87 Sabertooth, 16GB Ripjaws X, GTX 780 OC DirectCU II 3GB, M500 480GB, Caviar Black 2TB, Dual Red 4TBx2 (RAID 1), XFX Pro 850W 80+ Gold, Graphite Series 600T SE White
HTPC build: i5-750, Hyper 212+, P7P55D Pro, 8GB Ripjaws X, R6970 DirectCU II 2GB, Caviar Black 640GB/2TB, Caviar Green 3TB, Seagate Barracuda 3TB, Strider Plus 750W, CM 690 II Advanced
Mobile Media: Asus Transformer Infinity 32GB w/ keyboard dock
Old January 22, 2014, 07:20 PM
JD JD is offline
What OS are you using? Pretty sure since Windows 7, ISO burning has been built-in. I haven't used a 3rd party burning tool in ages.
Old January 22, 2014, 07:48 PM
Ooo win 7 64 bit
Old January 22, 2014, 09:28 PM
Shadowmeph's Avatar
have you tried imgburn? it works very well.
Somtimes whe na program is installed you might have to run it wil administrative privileges.
I had that problem when running the windows 8 and windows 8.1, I fixewd it by going into the properties and setting it to run as admin .
off topic here;
actually with the newer windows 8 and 8.1 I foudn to many things I didn't like so I went back to windows 7 all is working again lol
Old January 23, 2014, 06:22 AM
sswilson's Avatar
Native Win 7 ISO burning has always been flaky at best, even to the point of making it impossible to create a recovery disk.
Old January 23, 2014, 07:30 AM
JD JD is offline
Hmm interesting, never had any issues here. Maybe those ISO's were poorly formatted that you were trying to burn.
Old January 23, 2014, 08:13 AM
sswilson's Avatar
No... It literally would not burn a recovery disk from an ISO that windows itself creates. Multiple brands of both disks, and burners, as well as a fresh OS install. Pretty sure a quick Google of folks unable to use windows native backup disk will point to it not being just me.... ;-)
Old January 23, 2014, 08:59 AM
I really don't know why people don't use ImgBurn more often. Its so lightweight and works so well..
Old January 23, 2014, 09:30 AM
sswilson's Avatar
Windows 7 Native DVD Burning? ;)
Old January 23, 2014, 09:37 AM
Nodscene's Avatar
Hahaha.
I always use Imgbrn myself. Lighweight, quick, and works great.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
My GPU fan stopped working ShinraCorp Video Cards 12 May 10, 2013 12:39 PM
On board video stopped working Bar1234 CPU's and Motherboards 3 March 11, 2013 07:07 AM
Stopped working the next day? bvsbutthd101 Audio 0 July 20, 2012 05:42 PM
3d vision stopped working tranceholic Troubleshooting 0 March 25, 2012 08:24 PM
Mouse Stopped Working geokilla Peripherals 7 May 9, 2009 07:50 AM
