-   -   3TB's Partitioned As NTFS With MBR Out There? (http://www.hardwarecanucks.com/forum/storage/64745-3tbs-partitioned-ntfs-mbr-out-there.html)
Big_Al_C December 22, 2013 12:46 AM
Guys,
Windows 7 Pro SP1 64-Bit with an ASRock P67 PRO3 (B3) MoBo
that has a UEFI BIOS, i5-2500K and Corsair Vengeance 16 Gigs.
My C, D and E partitions are on a 120 GB NTFS SSD with a MBR.
My present STORAGE HDD is a 2TB Toshiba with a MBR.
I recently purchased a Toshiba PH3300U-1I72 3TB to replace the 2TB.
I always Ghost with DOS Bootable CDs I make with custom
Autoexec.bat files I write, never Windows.
I found out from Symantec that Ghost has issues with GPT.
I found a way to make my 3TB FULLY accessible and set as MBR.
It's Acronis True Image, aka Seagates DiskWizard aka WD's version
of DiskWizard. It puts an "Extended Capacity Manager" in the boot
sector so you get one 2.1TB and one 700+GB partition, BOTH MBR.
See: Seagate DiscWizard CloneDisc for drives larger than 3TB_Part-2
https://www.youtube.com/watch?v=TCLGfj1LSmI
The reason that I'm posting this is to get feedback from anyone who
has used these programs to see if the 3TBers work as any other HDD
would or are there any quirks that have come up since partitioning
your 3TB?
Please post to me.
Thanks in advance for your help.
Big Al
enaberif December 22, 2013 11:47 AM
Why bother tho? GPT is far better and properly supports 3TB drives.
Big_Al_C December 22, 2013 06:47 PM
Big_Al_C December 22, 2013 06:49 PM
BIG Update
Guys,
I just found this and would like some input before opening the
Toshiba 3TB's box:
Make SURE the 3TB is EMPTY as this will wipe ALL data on the drive
To make a fully accessible 3TB with 4k sector:
1. Boot to desktop.
2. Open "My Computer" in Windows Explorer.
3. Click on the EMPTY 3TB HDD.
4. If the factory made some partitions on it, delete them all.
5. Once it is just one disk, right-click it and click "Format"
6. Select "4096", "NTFS" and "Format".
7. Click OK. Since the 3TB is EMPTY, it should be real quick.
8. It's now ready to be partitioned to your liking up to 2.7 or so
TB's total and is set as MBR.
Big Al
Big_Al_C January 4, 2014 07:25 PM
The End Is Here
Sorry to say that I've heard from numerous people with 3+ TB's
and they have grave reservations about Acronis/Seagate/WD's
Extended Capacity Manager to get full MBR 3TB HDD's and they
say that the "4096", "NTFS" and "Format" won't work.
Well, I HATE to admit defeat, but since I CANNOT find the
Ghost v11.5.1.2298 from GSS 2.5.1 that DOES see GPT HDD's,
I've concluded that my only recourse is to relegate my 3TB to
GPT and to BACKUP status to my 2TB Toshiba and dusted-off 1TB
Hitachi MBR HDD's that I'll be using as my main drives.
After numerous E-Mails to a bunch of Cloning Software companies,
I've settled on MiniTool Partition Wizard v8.1.1 from
Free Partition Magic alternative, partition manager freeware, partition magic server, partition magic Windows 7 and free Partition Manager software for Windows 7/8/VISTA/XP/2000 and Windows Server 2003/2008/2000. (To top it off, it's FREE!!!)
to pre-partition my 3TBer and to do the "Copy partitions from
my 1 and 2TB MBR's to partitions on my 3TB GPT" and use my
Ghost v11.5.1.2269's Make and Restore Bootable CD's to do my
MBR C and D Drive imaging chores.
It's been fun--NOT!
Big Al
Robert January 6, 2014 10:43 AM
Symantec Ghost Solution Suite did put out a solution for 64 bit machines using uEFI. It does require that the user obtain from Microsoft the Windows Automated Deployment Kit (ADK) so that a WinPE 4.0 PreOS can be built. This URL will tell how to get the files from Microsoft and from Symantec such that a Ghost Boot Disk can be created. It will support the GPT file structure.
Using any other PreOS with a machine that uses uEFI instead of BIOS will probably create the image with no errors but the restored image will not boot the machine.
http://www.symantec.com/docs/HOWTO93846 -
How to create Ghost uEFI boot media with batch files.
