Old December 10, 2013, 08:15 PM
Default SY-PEX40039 with Asus ASUS F1-A75-M PRO/CSM? Best option?
Hey everyone,
It's been a while since I logged into here but I recently ran into a problem. I've got a close-to-two year old ASUS F1-A75-M PRO/CSM motherboard that only has 6 SATA ports on it.
One is used by my boot drive (SSD) and the other five are running drives for media storage. I'd like to add a drive or two more and not re-do the system since the A8-5400K I'm running is serving my purposes for media playback perfectly fine.
I was thinking about adding a SYBA SY-PEX40039 SATA3 card but I'm not sure if I'd get decent speeds or how I'd be best to install it. In my system, all PCI-E slots are empty (using on-board everything), so I was wondering if I can use the x16 slot as it's 2.0 for speed purposes or am I stuck using the x1 slot with the SATA2 speeds because of bottlenecking?
Motherboard specs and info here:
https://www.asus.com/Motherboards/F1A75M_PRO/
Add-on card here:
SYBAUSA - SY-PEX40039 >> SATA III 2 Internal 6Gbps Ports PCI-e Controller Card
Thanks to anybody who can help me with this.
Old January 10, 2014, 02:29 PM
MARSTG's Avatar
It will work just fine in either ports, x1 or x16.
Old January 12, 2014, 08:01 AM
Thank you for the reply and confirmation. ASUS also confirmed that this card should work as I'm not using Discrete Video.
Cheers!
eVGA 780i + Syba SY-PEX40039 PCIe Sata III card issue rarefx Storage 2 March 25, 2012 12:12 PM
[WTB] ASUS P8P67 WS REVOLUTION or ASUS MAXIMUS IV EXTREME (REV 3.0) OmegaRED Buy/Sell & Trade 8 November 17, 2011 09:33 AM
ASUS p6x58D Premium versus Asus Rampage Extreme III Timid newbe New Builds 2 August 17, 2010 01:09 PM
Installing SSD & W7 (Using Asus Recovery Disc) On Asus G51J Notebooks rjbarker Mobile Computing 0 February 19, 2010 12:36 PM
ASUS Rampage Extreme or ASUS Maximus II Formula AmuseMe CPU's and Motherboards 3 July 20, 2009 09:46 AM
