Old October 19, 2013, 06:31 PM
dlf dlf is offline
Default Seeking replacement external harddrive
I am seeking a replacement external hard drive that (according to CrystalDisk Info) has 4 bad sectors.
At lest 1.5 TB (although 2 TB may be better)
Should use:
  • USB 2.0 (or 3.0)
  • Or Firewire (incase all my other USB ports are taken)
  • Or eSata (that should be the fastest, yes?)
peas and tanks you (please and thank you)
Old October 19, 2013, 06:33 PM
Seagate GoFlex is my choice.
PS.. Finding things that use Firewire or eSata these days is not a simple task as most external devices have forgotton about this.
Old October 19, 2013, 06:37 PM
dlf dlf is offline
I don't use Mac, also from first search on Newegg the sizes - 1 TB and 500 GB seem too small.
1TB+ External HDD Case and 3.5" Drive OR External HDD Bond007 Storage 0 August 18, 2011 06:02 PM
Seeking AMD build advice Please. kir_b New Builds 30 April 12, 2011 12:37 AM
[FS] Storage! 1tb wd black/3tb seagate external/500gb 2.5" external/rocketraid 62x/62xm b1lk1 Buy/Sell & Trade 2 February 13, 2011 03:01 PM
Seeking advice - 775 Mobo, hdd's, ram mattydies CPU's and Motherboards 5 January 30, 2009 09:12 PM
Seeking MB's that have more than 4 SATA connectors antonin Storage 9 April 1, 2008 11:31 AM
