Old July 7, 2013, 08:15 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default Western Digital SE 4TB Hard Drive Review Comment Thread
Western Digital's SE 4TTB is a drive which targets entry level enterprise customers who are seeking a scalable, large capacity solution that can easily be expanded should the need arise.
Read more here: Western Digital SE 4TB Hard Drive Review (Single and RAID)
Old August 20, 2013, 02:18 AM
Dzzope's Avatar
Given a choice between the 2TB version of this and the black... What would you go for if the RE4 was $5 cheaper.?
What would the pro's and cons be in comparison?
I see mention that this isn't an ideal drive for home use but the RW tests shows it out performs the Black.
What is noise like? (Trying for a much quieter build)
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old August 20, 2013, 05:15 AM
SKYMTL's Avatar
It really depends what your needs are IMO (other than a quiet rig that is). The SE has a slightly lower MTBF but that really won't matter in a home-use environment.
Old August 20, 2013, 06:11 AM
Dzzope's Avatar
Mostly storage TBH but I'll be using it as a boot drive till I get my new SSD(s)
I guess performance isn't going to be much of an issue (not that I'll be able to notice between the 2..)
Is guess if the noise comparable to the black I'll get it.. if the black is MUCH quieter then i'll go for that...
Any idea's on spin-up time? once I have my SSD's disks go idle allot till I watch movies or play games that i don't want on SSD.
Cheers for the reply.
Random quotes:
Old August 20, 2013, 06:30 AM
great_big_abyss's Avatar
I find the spin up time on my Green's are atrocious. I'm assuming these would make a good replacement for a few 2TB Green's?
Scratch that. I was thinking of the Reds!
Old August 20, 2013, 01:54 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
I dont think you could wrong with any of them TBH. It will come down to a few isssues.
How long will you be using them as an OS drive? Weeks? Months? Short term the TLER issue is a non-issue. Long term...it can become one (usually not...but sometimes it can be). So it would be Black for long term. Short term RE.
How big a deal is noise levels? If its important...get the Black.
If neither is a big deal and the RE is cheaper than the SE...get the RE. For home use both are overkill..but why spend more for the SE when the RE is a bit more durable. Its louder though...so if noise is kinda sorta important (but TLER is not) the SE is the one to get.
Hope that helps put the three into perspective. :)
Old August 22, 2013, 06:02 AM
Dzzope's Avatar
Does indeed... Got the Black... Will be weeks / max 2 months as os (unless ssd dies) and noise is becoming more and more of a pet peve for me.
Cheers for the insight.
Random quotes:
Western Digital RE 4TB Hard Drive Review Comment Thread SKYMTL Storage 1 November 26, 2012 08:23 AM
Western Digital Caviar Green 3TB Hard Drive Review Comment Thread SKYMTL Storage 13 March 11, 2012 12:17 AM
Western Digital Caviar Black 2TB Hard Drive Review Comment Thread SKYMTL Storage 25 January 5, 2011 05:17 PM
Western Digital Caviar Green 2TB Hard Drive Review Comment Thread SKYMTL Storage 10 February 16, 2010 10:34 AM
Western Digital Caviar Black 1TB Hard Drive Review Comment Thread AkG Storage 14 May 2, 2009 07:43 AM
