Old June 23, 2013, 04:30 AM
Question HELP: Need A Hard Drive Replacement
Hi fellows,
What is the top of the line FAST internal hard drive for my Win 7 X64 operating system and games that you are recommending these days?
I will be using it for gaming on my desktop and other various computer tasks.
Thank you in advance for the advise.
Cordially,
CG
Old June 23, 2013, 05:24 AM
Dzzope's Avatar
you have an ssd?
Personally I'd go WD black for fast HDD, not too dear and 5 yr warranty.. used loads never had a failure (touches wood)
Seagate barracuda is SLIGHTLY faster but 2 yr warranty and seen loads fail. though my brother has one and had no issues yet.. also fairly cheap
WD Blue is good general use drive. 3yr warranty so not as high spec or fast as a Black but quieter and cheaper.
Raptor is the fastest but REALLY expensive for spindle drives.
Anything higher and your looking at server / enterprise stuff.
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
Old June 23, 2013, 06:37 AM
KaptCrunch's Avatar
Chess Gator
adding to system or main drive?
is your system OEM ? for has a hidden partition for factory restore
and its a HDD or SSD drive your wanting to use
if as a main and OEM need to clone orginale drive then keep it as back-up
Old June 23, 2013, 11:38 AM
Question
Hi, I am looking for a state of the art internal SSD. Is there one or two that stand out as the best? Or is there one that has just come out that is bleeding edge technology?
Thank you,
CG
Old June 23, 2013, 12:32 PM
Dzzope's Avatar
Nothing that is amazingly outstanding..
Personally I would get whichever of the top few that gives you good warranty.. so Intel 520.. annnd whatever else is good :D
Not had to do much with SSD's apart from using.. Just don't get something that you have to send to the states.. eg Samsung
Random quotes:
Old June 23, 2013, 04:06 PM
I really like the Samsung 840 series. Have used 6 so far. Other peeps might know more than me
Old June 23, 2013, 04:50 PM
IRQ Conflict's Avatar
*Cough*
Old June 24, 2013, 12:44 AM
Dzzope's Avatar
ah ha.. nice update.. Ignore the Sammy comment.
Random quotes:
Bad RMA replacement drive? Fix or return? Kitty Troubleshooting 9 December 17, 2011 06:10 PM
h70 fan replacement schweppes Air Cooling 0 January 20, 2011 01:10 PM
Replacement GTZ top? Pax Water Cooling 11 November 25, 2010 09:05 PM
replacement hard drive mo' power Mobile Computing 2 January 9, 2010 07:57 PM
New PSU and Fan replacement serenity Power Supplies 9 September 22, 2008 01:32 AM
