-   -   Missing Space? (http://www.hardwarecanucks.com/forum/storage/61810-missing-space.html)
r0k0 June 22, 2013 07:30 PM
Missing Space?
when I reformatted, I had 95gb free of 120gb..
I've put some files on my SSD until I got a spare HDD to put all my stuff back into the other HDD that I accidently deleted.. now I transferred everything back on the spare HDD but I have only 58.2GB free space on my SSD, and I removed everything else..
let me know what info I can provide for you guys to help me.. because before reformatting my SSD, i had BF3 with all new add ons, lots of pictures and music on my SSD and i had ~40gb left, now with nothing installed, no game, music or photos.. i have 58.2GB left
Any help is appreciated
ZZLEE June 22, 2013 07:44 PM
Try this utility Defraggler - Download
It will give a better idea of whats up with your drive.
My bets are on swap space.
or fragging.
MacJunky June 22, 2013 08:01 PM
Fragmentation does not result in loss of disk space.
I would suggest a program that shows what folder/files are using what space. I think I once used RidNacs and another one I have forgot the name of, but I do not know if it is considered good or not so YMMV.
Also, you do not need to defragment a SSD, and windows 8+your motherboard are new enough to support TRIM if you had a SSD that did not run it's own garbage collections routines.
IRQ Conflict June 22, 2013 08:01 PM
:shok: DO NOT DEFRAG AN SSD!
Just in case I didn't read it wrong. I have heard that defragmenting your ssd is a serious no no.
r0k0 June 22, 2013 08:07 PM
I've finished using it but im still at 63gb free space.... what the hell is using all my SSD data.. everywhere i look i cant seem to find large files..
enaberif June 22, 2013 08:07 PM
treesize free
will show you where space is and gone
r0k0 June 22, 2013 08:13 PM
http://img801.imageshack.us/img801/862/ztba.jpg
Uploaded with ImageShack.us
r0k0 June 22, 2013 08:16 PM
why is 42GB used between Windows folder, Pagefile.sys and hiberfil.sys ?
enaberif June 22, 2013 08:18 PM
1) Disable hibernatio as you have a ssd
2) Disable pagefile unless you have a mechanical drive to put it on
3) SxS directory probably chewing up space. Look in the folder
r0k0 June 22, 2013 08:19 PM
how do i do #1 and #2 ? :P
