Old June 22, 2013, 08:27 PM
Originally Posted by r0k0 View Post
how do i do #1 and #2 ? :P
google :p
Old June 22, 2013, 08:35 PM
r0k0's Avatar
I've disabled the page files and put it on my E: drive.. but when i look it up with ridnac or treesize, pagefiles.sys is still on C: even with it disable
Intel i7 3930K / 16GB Corsair Vengence DDR3-2400
Asus X79 Rampage Extreme Black Edition / EVGA GTX 770
Corsair 480GB SSD / 1TB WD Black
IN WIN 303 / EVGA NEX750 Gold
Old June 22, 2013, 10:36 PM
KaptCrunch's Avatar
is this ur ssd
ADATA S511 Series AS511S3-120GM-C 2.5" 120GB SATA III MLC Internal Solid State Drive
i see Firmware 5.0.7a
follow the instuctions to do it or got a paper waight
Old June 23, 2013, 05:53 AM
AlienIsGOD's Avatar
Originally Posted by enaberif View Post
google :p
awesome........ you're really going to tell OP to google it after YOU instructed him to do these things.... Your fingers must be lazy as hell to give someone advice and then when they ask how you tell them to "google" it. IF you had told him how to do it, other people would have seen this thread and had insructions to follow instead of picking a google post. Way to help the community.....
Gaming Rig (Gaming Cruncher): i5 3570K @ 4.2ghz, Sapphire RX 480 8GB, EVGA Z77 FTW Mobo, 8GB Mushkin Blackline DDR 3, Kingston SSDNOW V300 120GB | 1000GB Data, EVGA SuperNova 750w 80+ Gold, NZXT 810 Switch case
24/7 WCG Cruncher: i5 2400 @3.4ghz, Gigabyte HD Saphire 6870 1GB, AsRock Z68M/USB3 Mobo, 8GB HyperX DDR 3, 120GB HyperX Blue SSD | 1TB storage, CoolerMaster G750M 80+ Bronze, Thermaltake Soprano Snow Edition case
Old June 23, 2013, 06:07 AM
okay fine..
http://bit.ly/17vP5oc
http://bit.ly/17vPgQm
Old June 23, 2013, 06:18 AM
KaptCrunch's Avatar
1) Disable hibernatio as you have a ssd
2) Disable pagefile unless you have a mechanical drive to put it on
3) SxS directory probably chewing up space. Look in the folder
why is 42GB used between Windows folder, Pagefile.sys and hiberfil.sys ?
blind leading the blind
obviously its some back-up/ AV scanner app eg norton, Windows XP Mode
Old June 23, 2013, 07:58 AM
I will help when warranted. But I refuse to help people with something that takes 2 seconds to google and is a very common issue.
LOL really? Must have something better than that. You are aware that Windows XP Mode doesn't exist in HP right? It is only part of of Pro or higher.
The SxS directory can grow exponentially mine is sitting at almost 10gb
Old June 23, 2013, 08:14 AM
KaptCrunch's Avatar
i agree they will suck the knowledge from you with their tenticle, and defeat the porpoise of learning.
op'ER OS: Windows 7 Ultimate X64
  #19 (permalink)
Old June 23, 2013, 12:43 PM
r0k0's Avatar
Where is the SxS thing ?
Also i've google those 2 first tips so it was all good guys
I'm up at 74gb now which is better
  #20 (permalink)
Old June 25, 2013, 05:45 PM
r0k0's Avatar
90.3GB Oh yeah !!!
Thanks guys !
What am I missing ? BrainEater HardwareCanucks F@H Team 18 October 24, 2012 07:12 AM
missing space on my ssd? Goon3d Storage 9 September 5, 2012 01:55 PM
Am i missing something? supaflyx3 Off Topic 4 August 6, 2011 05:15 PM
Am I missing anything? bvsbutthd101 Water Cooling 43 July 12, 2011 05:30 PM
What Am I Missing? El_Fiendo Off Topic 8 October 14, 2009 06:39 PM
