Old June 5, 2013, 04:34 PM
KRAFTIG's Avatar
Default Help! Recent HD install Questions
Hey guys, I recently installed a WD 2TB HD, all seems to of went well but today I noticed the drive shows up as removable and a SCSI Disk Device. This is definitely SATA drive, how can I fix both issues? TIA!
Old June 5, 2013, 04:49 PM
Normal behavior due to AHCI drivers.
Old June 5, 2013, 05:33 PM
KRAFTIG's Avatar
Really. Why? Is is because of the size or number of drives? I don't think the drive show up under the BIOS either.
Old June 5, 2013, 05:43 PM
great_big_abyss's Avatar
You can change this in the bios. Likely the specific SATA port is set to AHCI, and also has 'hot swap' or some similar term enabled. Turn off 'hot swap' and you should be good. It may be labeled something different, depending on the motherboard type. Make sure you change it for the specific sata port that your drive is plugged into.
Old June 5, 2013, 06:12 PM
JD JD is offline
I think installing Intel RST (assuming this is an Intel chipset motherboard) might get rid of it? Not 100% sure though.
Old June 5, 2013, 06:13 PM
KRAFTIG's Avatar
Like I said the drive doesn't show up in the bios. I have a total of seven devices and only 6 show up.
You mention 'hot swap', under SATA options I see 'hot plug'. It is disabled for all 6 devices it sees. The 7th device being the new 2TB HD is not showing but working within Windows but has these issues. Strange...
Old June 5, 2013, 06:14 PM
JD JD is offline
Okay, sounds like your new drive is on a different SATA controller.
What motherboard is this?
Old June 5, 2013, 06:31 PM
KRAFTIG's Avatar
ASUS P8P67 Pro Rev 3.1 - There are a total of 8 SATA ports. IN sequence the first four are light blue, next two are white, last 2 are dark blue - this is where the new 2TB HD is plugged into.
Old June 6, 2013, 02:24 PM
KRAFTIG's Avatar
Anyone?
Old June 6, 2013, 03:43 PM
KRAFTIG's Avatar
I've discovered the last two SATA are Marvell Serial ATA 6.0 Gb/s connectors while the other 6 are Intel P67 6.0 Gb/S and 3.0 Gb/s connectors. What is the difference and why do they behave differently? TIA!
My Recent PC Upgrade TehFlash New Builds 3 December 25, 2011 02:17 AM
My Very Recent build shelfelf New Builds 1 September 23, 2011 12:00 PM
Recent power problem The Package Troubleshooting 1 May 28, 2011 06:47 PM
[WTB] PC Games (recent, semi-recent) Koslov Buy/Sell & Trade 2 April 6, 2010 02:49 PM
Ga ma790x-ud4 install questions? upcoast604 CPU's and Motherboards 2 February 24, 2009 02:05 PM
