Old June 6, 2013, 04:51 PM
ipaine's Avatar
You are connected into the Marvell controller. You can see the options for that in the bios on the following screen.
Normally if the drive is plugged into one of the Intel ports and you have the Intel RST drivers installed they will not show up as removable. But that (I believe) doesn't apply to any drives connected to the marvell controller. One of the differences between the two controllers is that Trim doesn't work with the Marvell controllers. Well at least it used to be like that, it might have changed with driver updates.
Oh and I believe this is where you can set it so they don't show up in removable devices. Oh and that should say right click and select properties. (I didn't add all the red highlighting just found the picture that way)
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old June 6, 2013, 06:43 PM
KRAFTIG's Avatar
Thank you sir, problem solved :)
Old June 6, 2013, 07:39 PM
You do realize it makes no difference having that there right?
Old June 6, 2013, 07:41 PM
KRAFTIG's Avatar
OCD feels much better though :)
Old June 7, 2013, 09:14 AM
Dzzope's Avatar
LOL, good answer. :)
Old June 7, 2013, 02:00 PM
KRAFTIG's Avatar
Thank you
My Recent PC Upgrade TehFlash New Builds 3 December 25, 2011 02:17 AM
My Very Recent build shelfelf New Builds 1 September 23, 2011 12:00 PM
Recent power problem The Package Troubleshooting 1 May 28, 2011 06:47 PM
[WTB] PC Games (recent, semi-recent) Koslov Buy/Sell & Trade 2 April 6, 2010 02:49 PM
Ga ma790x-ud4 install questions? upcoast604 CPU's and Motherboards 2 February 24, 2009 02:05 PM
