Old May 31, 2013, 03:39 AM
Exclamation "At Risk" HDD message on WD drive
I was messing with my daughters computer installing a printer and I noticed an error message and clicked on it. It said the HDD was "at Risk". I think the program was Intel's Rapid Storage Tech program but wasn't paying enough attention. When I tried to find out more the program gave me the drive's type, serial #, port, firmware, etc. but I have no idea what "At Risk" means or what I should do with it.
Does it mean the drive is failing? What should my next course of action be?
HDD is a WD1002FAEX-00Z3AO with firmware 05.01D05.
I reset the message and it came back once. Reset it again but then went to bed. Computer seems to be working fine other than that message.
Old May 31, 2013, 05:09 AM
HDD is failing. Use WD Tools or Seatools to do a Short/Long test on it.
Old May 31, 2013, 05:31 AM
Wait,check it with crystal disk info,what does it say?
Old May 31, 2013, 08:32 AM
"Quote This..."
That is the HD's S.M.A.R.T. technology telling you it is at risk, threw an error.
S.M.A.R.T. - Wikipedia, the free encyclopedia.
I've had many drives do this over the years and not one of them actually failed. I now ignore this message.
You should always be doing backups anyways. HD fails, pop in a new one and restore. Simple.
"BF3.3" Level 10 GT Case Mod is "Locked and Loaded" Mnpctech Cases 2 July 12, 2012 12:18 PM
How do i know if my "Drive Controller" is running in "AHCI mode"? Teo3201 Storage 2 October 8, 2011 09:54 PM
Cannot access hard drive: "disk boot failure" nlts Troubleshooting 10 May 13, 2011 07:15 AM
How do I set my second hard drive as a "data drive"? lsquare Storage 11 March 19, 2010 09:11 PM
