Old May 20, 2013, 06:39 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default Seagate Desktop HDD.15 4TB Hard Drive Review Comment Thread
Seagate has begun a complete top to bottom refresh of their hard drive lineup and the Desktop HDD.15 4TB is their latest addition. This HDD houses impressive amounts of storage space and even though its 5900RPM speed may be slow by today's standards, performance is actually quite surprising.
Read more here: http://www.hardwarecanucks.com/forum...ve-review.html
Old May 21, 2013, 02:49 PM
They did an interview about phasing out low rpm drives (green) a while back with Linus Seagate Interview - Barracuda Products & Power of One NCIX Tech Tips - YouTube
Not exactly sure why they would go back low RPM again. The power savings per year for 24/7 usage between the two is ~74cents. Might as well just give it a boost in performance..
Old May 21, 2013, 03:11 PM
People don't buy a 4TB drive for speed. They buy them for storage and because of this they still want some decent speed behind the drive. A 4TB storage drive doesn't need to be 7200rpm
Old May 21, 2013, 03:39 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
They did because they are going to tack on X number of NANC ICs...and make a monster Desktop Hybrid. Why use a 7200rpmer when you have NAND. ;)
Old May 21, 2013, 05:50 PM
SKYMTL's Avatar
Whoops!
Old May 21, 2013, 07:53 PM
My point is, in the interview, they gave so many reasons as to why having a lower RPM is a bad thing. Like there's absolutely NO good reason for it, and then they do a 180.
It costs pretty much the same, if not less, to put out 7200rpm drives than it is to put out 5900rpm drives.
Considering the drive costs almost $200 after it's all said and done, you sacrifice a decent % of performance to save a few cents per year in electricity costs? The ratio isn't even close at all.
Old May 22, 2013, 06:11 AM
AkG's Avatar
AkG AkG is offline
I understand exactly what you are saying and for the most part do agree.
Couple things to remeber though, Seagate - like WD - are simplifying their parts channel and models. Seagate is going to be taking Hybrids seriously. For Hybrids a 7200rpm drive is not really needed (IF they use enough NAND...which was the issue I had with their laptop hybrid model). To do 7200rpm 4TB desktop model and a 5900 Hybrid model would require two mfg'ering lines. Whereas 'now' they only need one. Build the Drive....and simply attach a different PCB to it to change it from a standalone HDD into a Hybrid. This keeps costs down. And Yes while this drive is 2bills...that is how much a 3TB cost peeps when 3TB was the flagship...so its only 2Bill for a 4TB drive. That in one gen is a reduction from $66 a TB to $50 a TB.
ALSO this drive is dead silent and even under random loads barely makes a peep, chirp or anything. When I first powered it on...I was worried that it was working...its that silent.
Taken as awhole I wouldnt pick it for an OS (its not a 'bad' choice...just that I use SSDs exclusively), but for data its a very good choice.
YMMV
Old May 24, 2013, 12:50 AM
EmptyMellon's Avatar
Excuse my ignorance, but what is the reason for using Vista instead of Windows 7 for the boot time HDD tests?
Old May 24, 2013, 05:19 AM
SKYMTL's Avatar
Vista is extremely slow starting. If a system boots quickly under Vista, performance under Win7 will be even better. It's simply a worst case scenario.
Old May 24, 2013, 01:44 PM
Without the intension of being a smartass, why use a slower HDD on a Vista boot test and a faster SSD on a W7? [If this was answered somewhere else please do provide the link.] However, for comparison between the HDD to SSD reviews, I think, it would be nice to see the relative difference of actual boot times, as the HDD's relate to SSD's times, under the same scenario.
Western Digital RE 4TB Hard Drive Review Comment Thread SKYMTL Storage 1 November 26, 2012 08:23 AM
Seagate Momentus XT 750GB Hybrid Hard Drive Review Comment Thread SKYMTL Storage 2 November 29, 2011 06:04 PM
Seagate Barracuda XT 3TB Hard Drive Review Comment Thread SKYMTL Storage 13 April 2, 2011 01:02 PM
Seagate Momentus XT 500GB Hybrid Hard Drive Review Comment Thread SKYMTL Storage 23 January 18, 2011 06:51 AM
