Old March 19, 2013, 01:08 PM
Default Enabling AHCI after Installing Win 7
I'm new to this forum but visit this site often just wondering if anyone else had this install problem.
I just applied another tweak which I found to speed up the overall performance of my PC. During my install of Windows 7 on my Gigabyte board I could not get the Hard drive to boot or load the Win 7 install in AHCI mode so I just settled for running my system in Legacy "IDE" mode.
After some time I was still bothered by the fact that my new motherboard had the AHCI feature but I could not get it to work. So I researched several websites including the Microsoft web site where I finally found the fix for my dilemmna here's the link http://support.microsoft.com/kb/922976
(note the registry tweak calls for changing the setting to "0" but you also have to select the decimal option as well not hexadecimal.)
This solution is for non-Intel chipsets, Intel has their own drivers in the form of the Intel Rapid Storage Technology Drivers
There is a registry fix for this problem but you have to change the registry MSahci setting first before you change the AHCI mode in your BIOS otherwise windows will not know to load the AHCI drivers which enable the more advanced disk control features of the SATA 3 specification mainly the NCQ feature and Trim for Windows 7 users that have SSD's.
Once this registry fix was completed my system realized a noticable performance boost really happy I figured this one out, now really enjoying the benifits of the SATA 3 technology which makes my PC run much quicker now.
Tomahawk out
Windows 7 64 bit
AMD FX 8350 8 core CPU @ 4.2 Ghz
Gigabyte 990XA-UD3 AM3+ Motherboard
(On board Cirrus Logic sound chip/W Dolby Digital)
16 gigs of Kingston Hyper X Ram@ 1366
750 Gb Seagate Momentus XT Hybrid Drive /W 8Gb hi speed internal nand flash
XFX AMD Radeon HD 6950 2 Gb vram
Corsair GS700W PSU
Old March 19, 2013, 01:48 PM
Did the same on my HTPC a few days back. Thought I had already done it when I built it but I guess I was wrong. It does make quite the difference with an SSD thats for sure.
Old March 20, 2013, 04:30 AM
wow thats really helpful. Thanks a lot!
Old March 23, 2013, 12:28 AM
MARSTG's Avatar
for HDDs there is no noticeable boost in performance using AHCI mode, the boost is for SSDs only. At least that is my experience.
Old March 23, 2013, 09:44 AM
Perineum's Avatar
It still helps with HDs. Explaination here: Why do i need AHCI with a SSD Drive (Guide Here!) ... - Crucial Community
Crossfire not Enabling r0k0 Video Cards 12 April 29, 2011 02:28 PM
gtx460 SLI enabling it importpsycho Video Cards 7 October 8, 2010 10:30 AM
Enabling AHCI on a EVGA 750i FTW and is it really required for SSD TALON CPU's and Motherboards 3 August 15, 2010 05:48 PM
Will enabling AHCI boost performance? Matt Storage 17 February 20, 2010 07:22 PM
Enabling supersampling AA on 4870x2? divertiti Video Cards 0 February 2, 2010 04:49 PM
