Old March 13, 2013, 11:10 AM
Question IDE cable ?
Hi ! I put my hands on a few old IDE hard drives. They were in their respective cases with their respective motherboard. And i noticed all IDE "cables" i've found can only support up to 2 drives... Do you know if there are "cables" that can support more ?
thanks !
(I say "cable" because it looks like a flat bunch of cables glued together lol)
Old March 13, 2013, 11:11 AM
Lpfan4ever's Avatar
IDE headers can only handle two drives, master and slave.
Originally Posted by encorp
Code:
<firebane> slightly used
Old March 13, 2013, 02:12 PM
ok... :(
and i also have an optical drive connected to somewhere else on the board, but the "flat cables" look the same... do you think i can plug a HDD there instead of the CD player ?
Old March 13, 2013, 02:41 PM
SugarJ's Avatar
Yes. The IDE connections for CD/DVD drives are the same as HDD drives. And they are called ribbon cables in North America, because they look a bit like sewing ribbons. Wide and flat.
Old March 13, 2013, 03:19 PM
ok ! so i can have up to 2 drives per ribbon is that correct ?
EDIT : and should i set it in slave mode ?
Old March 13, 2013, 07:18 PM
Bloodystumps's Avatar
yes that is correct 2 drives per ribbon ...Try setting it to C/S (cable select)
Old March 14, 2013, 07:54 AM
NyteOwl's Avatar
For maximum performance put the optical drive on a different header to the hard drives. If you must put them on the same cable, make sure the HDD is master and the optical drive the slave for optimum drive performance.
Obsolescence is just a lack of imagination.
Tags
cable , hard drive , ide
[FS] Xbox 360: Halo 3 ODST, HDMI AV Cable, VGA AV Cable (All Brand New) icarus2 Buy/Sell & Trade 1 December 20, 2009 12:30 PM
[WTB] Need VGA cable b1lk1 Buy/Sell & Trade 4 September 23, 2009 09:50 AM
$5 cable for $50? artistpavel Off Topic 8 September 2, 2009 01:47 PM
2-pin Y cable? anyone know where to get them? dmccaulley Troubleshooting 6 June 27, 2009 12:05 AM
