Old February 9, 2013, 09:41 PM
Default Advice on file storage on small SSD
I got my hands on 2 Kingston SSDNow 100V 64GB from my uncle but don't know how to really use them. The size of the SSD means that I have to pick what to put on there. I'm thinking about the following set up:
Drive 1: Windows 7 install and all other software excluding Steam.
Drive 2: Steam only
Old 500GB: All Firefox download, User data, and VM files (this was on a slow 2TB Seagate).
I'm using an AMD 970 chipped motherboards so I can't really use it for caching. More like I haven't seen any solutions that I like. Any suggestions are welcome.
Old February 10, 2013, 05:54 AM
WhippWhapp's Avatar
Silverstone HDDBoost at Memory Express
My uncle uses one with an Intel 40gb ssd, works well enough.
I rub and whack and choke and stroke!
Old February 10, 2013, 12:32 PM
I already looked at the Silverstone HDDBoost and I don't think I'll use it. It just cache the front X amount of the HDD to fill the SSD and that's all. It doesn't pick frequent used files like Intel SRT or software like Dataplex.
Old February 10, 2013, 03:04 PM
WhippWhapp's Avatar
As long as keep your hdd defragged, it achieves the same thing?
Either that or pony up for a z68 or 77?
Old February 13, 2013, 04:10 PM
tangrisser's Avatar
Do you want Windows to load faster or the games?
If you only have a few games, try to find a way to install Windows + Steam on SSD and move everything else onto a separate hard drive.
If it can't be done then decide based on what you wait most often. Personally I rarely turn off computer so I don't need Windows to be on SSD (although it is.) but games are something I have to load every time I play so it makes sense for me to put games on SSD if I had space constraint.
Check out my SALE page
Old February 13, 2013, 05:10 PM
I think I'll go with my initial setting and use SteamTool to move games to and from the SSD. So for games that I don't play often, I'll just move it to the HDD.
Cheap small mcquiet gaming system, matx or small atx? Poison Ivy New Builds 17 December 29, 2011 10:17 PM
[WTB] Small sub-netbook. around 5 inches. Fujitsu Lifebook U1010/U810 etc... Small!! oblisk Buy/Sell & Trade 1 November 1, 2010 02:36 PM
TPR file??? martin_metal_88 HardwareCanucks F@H Team 8 January 17, 2010 11:55 AM
Storage upgrade - RAID advice serenity Storage 1 February 22, 2009 10:08 AM
Help with .reg file Shadowmeph O/S's, Drivers & General Software 5 January 29, 2009 05:04 PM
