Old February 1, 2013, 10:00 AM
Question Molex cables ?
Hi ! I just bought and UBS to SATA/IDE adapter. I've got 2 SATA to molex adapters for power supply, but one i have 3 wires, and the other one, 4 cables ! (the added one is yellow...)
Can someone tell me the difference between the 2 cables ? And how do i know my drive needs a 3 pins or a 4 pins adapter ?
Thank you !
Old February 1, 2013, 10:20 AM
Soultribunal's Avatar
Thank you !
Hi there,
The yellow cable is the 12V line, which you will need for your HDD.
So use the one with 4 total,
-ST
Old February 1, 2013, 11:52 AM
botat29's Avatar
Yellow -> 12v
Red - > 5 v
Black - > Ground
If the red is not there it's probably an adapter for fans, if I'm not mistake HD need both 5 and 12 volts.
Old February 1, 2013, 02:32 PM
Ok... so obvisously you guys are saying i should use the adapter with the yellow cable, and i will ! But how can the other one be for a fan ? It's a SATA to Molex adapter ! Do you think they might have... forgot to put a wire ??
Old February 1, 2013, 02:46 PM
ZZLEE's Avatar
Picture of it ?? size it down to fit forum rules.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old February 1, 2013, 06:09 PM
i cant post any picture. It's just a standard SATA to Molex adapter, without any yellow cable...
Old February 1, 2013, 06:16 PM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
Does it have all FOUR cables attached to the molex plug....or just two. If its two its a fan adapater. If it attached to all four pins of hte Molex connector and USES all four (ie with four cables going to the Sata plug) it should be a hdd adapter.
Old February 1, 2013, 06:27 PM
3.0charlie's Avatar
Is this it?
Old February 1, 2013, 07:55 PM
ZZLEE's Avatar
LOL ... " Somewhere, an electric company is salivating..."
Old February 2, 2013, 08:12 AM
Ok ! So yes for the 4 pin, all 4 cables a plugged into both SATA side and Molex side. The 3 wires adapter, all 3 wires are plugged (and the molex only has 3 metal pins).
The picture "Pscout" posted is pretty accurate, except the SATA connetor seems to be a male on the picture, whereas mine is female...
And i really don't understand that "fan" thing. Ho can it be related to a fan since it's SATA ? i thought SATA was only for storage devices, not fans...
Tags
adapter , molex , power , sata
Buying molex cables in bulk. Wholesalers? bigFOIG Off Topic 11 June 12, 2012 07:07 PM
[FS] Speaker wire, Audio cables, video cables, VGA, ethernet, AdoP Buy/Sell & Trade 12 December 6, 2010 12:32 PM
How should I add some extra molex? moufen2 Power Supplies 7 September 29, 2010 07:08 PM
Molex Alternative? Xillion Peripherals 7 August 11, 2009 05:46 AM
4 pin molex connector Phobia Off Topic 9 June 2, 2009 12:59 AM
