Old January 29, 2013, 05:19 AM
Question RAID compatable?
I've got a bunch of questions:
1.i have an asus P8B75-V, Socket-1155 motherboard and i was wondering if it is raid campatable. i am thinking about getting two 64 gb ssd's to put in raid 0 for crazy R/W speed. my budget is quite restricted so 64 gb is all i can afford. each drive has 490 mb/s read and 240 mb/s write.
2. if i have 2 ssd's in raid 0, can i back them up with one or two additionel drives in raid 1? and if so, will a old, slow hdd slow the R/W speed down to it's own speed? i want them to cooperate with eachother like in raid 10.
3. if my motherboard isn't compadable, will a dedecated pci raid card do the trick?
4. im hoping that i can achieve raid 10 on my pc but the the raid card that's available to me right now says in the description that it only handels raid 1 and 0. so how do i setup raid 10? i have 2 old hdd's which i was hoping to use as backups drives for the raid 0 ssd array.
answres are much appreciated.
Old January 29, 2013, 08:08 AM
"Quote This..."
The B75 express chipset on your mobo supports raid 0,1,5 and 10. But you can't mirror a raid stripe onto different hardware. Put your ssd's in raid0 and run nightly or weekly backups to a storage drive.
Black belt in CAPS LOCK.
Old January 29, 2013, 10:07 AM
can you backup the hole drive? i know hiw to backup word, project and game progress files but i do not know how to make a complete backup of a drive.
Old January 29, 2013, 03:10 PM
gingerbee's Avatar
acronis for the raid 0 drive back up works fast and
Tags
question , raid 0 , ssd
Are all windows 7 programs backwards compatable with windows 8? Chris65478 O/S's, Drivers & General Software 5 December 5, 2012 07:14 AM
is my ram is compatable with the DFI P35-T2RS Shadowmeph CPU's and Motherboards 1 July 14, 2009 09:07 PM
What is a good backplate compatable heatsink? Peppaaro Air Cooling 11 February 25, 2009 07:08 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
e8400 Compatable Motherboards Fissureman CPU's and Motherboards 19 February 25, 2008 12:12 PM
