my ssd atio disk benchmark result i am not ssd expert... ocz tech support asked me to blah blah... so i did.. pretty late... anyway here is the result... and no errors... ( ocz vertex2 60gb ssd) http://imageshack.us/a/img543/928/capture1cm.png http://imageshack.us/a/img267/3839/capture2uw.png Quote:
anyway what do you think... do you trust ocz tech support? |
I trust OCZ like I trust a 1000$ bill. I've had many clients buy OCZ parts just for them to come and ask what's wrong, when ever that's OCZ power supply or OCZ RAM they both are horrible. They're cheap but they're cheap for a reason. Sacrifice quality and durability for cheapness. |
yes i understand your point of view... i am talking about ssd.. did you read news about ssd? my ssd is 2 years old... plus i had this black screen+frozen keyboard problem that unknown to me for many couples... i did blame on asus and ati but i am wrong... Quote:
obviously not worth to me... i will sell it... but i still would like to know which is the better most harsh stress test for ssd... you know degraf wont work... |
If you want the hardest test possible....setup IOMeter. Config it to use the entire capacity of the EMPTY SSD. Set it to 50/50 r/w. 100% random. 4K file size at a couple dif queue depths....and let it hammer the drive for 6 -8 hours. It will kick the snot out of the drive. IF there is a problem...it WILL fail. Do a secure erase afterward and then repeat it 2 or 3 more times and you can be damn well sure if the drive is good or not. ;) It will use up a couple of the NAND p/e cycles per test. BUT even if it uses 50 or 100....that still small potatoes (ie less than 1% at most of the life span). IMHO ATTO is all well and good...but on SandForce drives which do auto compression...it wont test all the NAND. Got a couple iffy blocks of NAND...or an iffy controller. It could easily pass that softball test. IOM on the other hand...is the big leagues and will push it to its limits. YMMV |
thank you very much... i waited for that very good answer... will do this weekend.. i have to study for test by tomorrow... |
| All times are GMT -7. The time now is 10:36 AM. |
