the mentioned drives are all good.
Provided you have a decent AMD motherboard, it won`t matter all that much which brand you use, as the controller(sata) is what counts for the speeds your drive is able to show you.
I am using a lowly OCZ Agility 3 on my M5A99X EVO and it works just fine, if ther eis any drives to have issues with any board it would be sandforce based.
Sammy 840/830, Corsair Neutron, Corsair Force GT, then the rest.
dont forget to do the general tweaks for SSD use, turning off prefetch and the like.
