Old January 7, 2013, 05:42 PM
concinnity's Avatar
Question Four Drive RAID Card
Looking for suggestions on good RAID cards for around $200 (Plus or minus $50) with RAID 10 functionality.
Getting information off the Internet is like taking a drink from a fire hydrant.
Old January 7, 2013, 06:32 PM
BlueByte's Avatar
I like LSI and Highpoint over adaptec these days. I find adaptec has fallen behind.
If you only need RAID 10
NCIX.com - Canada's Premier Computer Store - Online PC Discount Store, Buy Computer Accessories PACKARD
If you might want something more like RAID 5
LSI MegaRAID 9240-4I 4 Port 6Gbps PCIEx8 Low Profile SAS/SATA/RAID Controller Card Kit With Cables
Highpoint Option that would only be good for raid 0,1,10
Highpoint Rocketraid 2720SGL 8 Port SATA/SAS Low Profile PCI-E Controller Card 2720SGL&manufacture=Highpoint Technologies
None of these will be great for RAID 5,6 etc down the road, two of the cards can do it but I would not suggest it.
Old January 7, 2013, 09:49 PM
Master_Shake_'s Avatar
how do you feel about used??
LSI RAID CARD MegaRAID MR 8888-ELP 8 port SAS SATA PCI-e SFF8087 SFF8088 Cable | eBay
Old January 7, 2013, 10:46 PM
lowfat's Avatar
You can get an IBM m1015 off eBay for about $125 shipped to Canada. It is the same as an LSI 9211-8i.
Old January 7, 2013, 10:56 PM
dustin1706's Avatar
+1 for the 9240.
I can't comment as to the other cards, but do be aware that the LSI cards "may" have compatibility issues with UEFI bios's. I got lucky and was able to make mine work with my P8Z77-I after significant amounts of messing about. If you are using an older board it's not an issue.
Rig1 in "My System Specs"
Rig2: Q6600, P5DN-D, GTX650, 4GB HyperX, LG BD drive, TT armor case, ek supreme HF, 655 pump, XP
Dell XPS17 - i7 2820QM, 8GB ram, 1920x1080, BluRay, GT555m 3GB, 240gb Neutron GTX, 640GB Seagate, Win7 64
Server - i5 3450, Asus P8Z77-I Deluxe, 4GB DDR3, LSI MegaRAID 9240-8I, OCZ Vertex 4 120GB, 2x SG Barracuda 3TB(RAID1), 2x WD green 2TB(RAID1), Fractal Design Array R2, WHS 2011
Old January 8, 2013, 10:23 AM
my 9260-4i works on a sapphire pure black p67 hydra, flawlessly.
Old January 8, 2013, 10:28 AM
grinder's Avatar
Seems all of the top OEM's are re branded LSI chips (Dell, etc.)... pretty much can't go wrong.
replacing raid drive how to question spudmatic Storage 8 January 5, 2013 09:51 AM
Dying Drive in RAID? xilocient Troubleshooting 9 December 8, 2011 05:32 PM
What is the best 1TB hard drive for RAID? TheGregster76 Storage 20 June 23, 2010 10:48 PM
can I set up raid separate from my SSD drive? Shadowmeph Storage 4 June 1, 2010 05:09 PM
9 drive ssd raid 0 array tzetsin Storage 3 May 3, 2008 11:03 AM
