<~----> what's the diff between PCI express x1 and 2.0? - Hardware Canucks
Old January 5, 2013, 09:05 AM
Wink what's the diff between PCI express x1 and 2.0?
First what I am trying to do is add more SATA ports to my motherboard and not spend $300 to do it.
I have a GIGABYTE GA-Z77X-UP4 TH LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard running win 7 64 bit and I am looking at new egg for controllers and I see some cheap controllers but they say PCI Express x1 or some say PCI Express 2.0.
For example:
Newegg.com - SYBA SY-PEX40052 PCI-Express x1 Low Profile Ready SATA III (6.0Gb/s) HyperDuo SSD and SATA 6G HDD Controller Card
and this
Newegg.com - SYBA SY-PEX40039 PCI-Express 2.0 SATA III (6.0Gb/s) Controller Card
they look like they go in the same slot so what's the difference? Looking at the MB it says there are three PCI Express x1 slots. I know you are thinking to yourself "just buy the one that says goes in your motherboard" but I am curious as to what the difference is.
I'd like to add something to the PCI Express 3.0 slot but the cheapest thing I find is this for $300
Newegg.com - LSI LSI00301 (9207-8i) PCI-Express 3.0 x8 Low Profile SATA / SAS Host Controller Card
Any brilliant thoughts?
Old January 5, 2013, 09:06 AM
For example:
and this
They are the same. PCI-E x1 is the slot type PCI-E 2.0 is the revision.
Old January 5, 2013, 09:17 AM
so why 2 versions of essentially the same thing made by the same manufacturer?
and is either of these controller chips better than the other
ASM1061 Chipset (Asmedia 1061 SATA Host Controller) on a $23 board
or
Marvell 9128 Chipset on a $30 board
Old January 5, 2013, 02:48 PM
The revision is a bump in maximum bandwidth.
Per wiki
PCI-SIG announced the availability of the PCI Express Base 2.0 specification on 15 January 2007.[17] The PCIe 2.0 standard doubles the transfer rate compared with PCIe 1.0 to 5 GT/s and the per-lane throughput rises from 250 MB/s to 500 MB/s. This means a 32-lane PCIe connector (×32) can support throughput up to 16 GB/s aggregate.
PCI Express - Wikipedia, the free encyclopedia
Old January 5, 2013, 04:00 PM
I see. Ok thanks for the info.
Will there be a performance Diff. ? MegMind Video Cards 5 November 16, 2011 09:17 AM
deciding between a couple diff GTX 260s sindraod Video Cards 3 December 18, 2009 10:03 AM
Does the 9400 GT 1024MB PCI Express 2.0 work on PCI Express x16 slot? aleo Video Cards 9 June 8, 2009 05:47 PM
What's the diff between buy a lcd tv and an lcd monitor? Mark Display Units 9 October 27, 2008 07:38 AM
On a 8800GTS 512 what is the diff between A3 and Ar?? bushwickbill Video Cards 2 April 16, 2008 07:50 PM
