-   -   sata controller (http://www.hardwarecanucks.com/forum/storage/58760-sata-controller.html)
rob123 December 27, 2012 02:18 PM
sata controller
will soon need more sata ports than available on my motherboard. i used to use a promise controller. now i see "sata raid" cards. i dont want raid, at all. basically just a card that i can hook extra drives up to.
some of the "sata raid" cards are a ridiculous price too. something reliable but n the lower end of the price scale.
thx for any info
rob123
supaflyx3 December 27, 2012 02:25 PM
Dell PERC 5/i
JD December 27, 2012 02:42 PM
I'm guessing something like these would be sufficient if you just want more ports without RAID:
Newegg.ca - HighPoint Rocket 640L PCI-Express 2.0 x4 Low Profile SATA III (6.0Gb/s) RAID Controller Card (4 SATA)
Newegg.ca - HighPoint RocketRAID 2680 SGL PCI-Express x4 Low Profile SATA / SAS RAID Controller Card (8 SATA via 2 miniSAS cables)
rob123 December 28, 2012 10:21 AM
so even though both of those advertise their raid capabilities, i can use them as extra sata ports for my motherboard and not use the raid at all?
thx
rob123
Generic User #2 December 28, 2012 01:55 PM
so the 'JBOD' specification for RAID cards isn't necessary?
JD December 28, 2012 10:26 PM
By default they'll just show as single drives. Only becomes RAID if you setup an array.
No, unless you want to group all your drives into a massive chunk of space. No point of doing this at the card level anyways since you can do it within Windows (dynamic disks).
Generic User #2 December 28, 2012 11:12 PM
oh....apparently i totally misunderstood what JBOD meant. I always thought JBOD was equivalent to plugging into the motherboard; each drive gets its own letter, partitions notwithstanding.
so i JBOD a bunch of disks, it'll appear as a single huge drive and when i write to it, the data gets randomly stored to one of the disks?
JD December 29, 2012 12:51 PM
Correct. So let's say you have 4x 1TB drives in JBOD. It would show as a single 4TB drive in Windows. You have no idea where your data resides.
NyteOwl December 29, 2012 01:15 PM
JBOD (just a bunch of disks) is exactly that - each disk is independent. There is no collective property or dependence. Each behaves as a separate drive and no special software is required.
For example in JBOD mode, disk1, disk2, disk3 disk4 are seen as E:, F: G:, H:
Where all the physical disks are concatenated into a single "disk", is properly known as disk spanning (sometimes a BIG disk) but is not JBOD. This needs to be implemented in either controller firmware or OS software or a combination of both.
For example in SPAN mode disk1, disk2, disk3, disk4 are seen as one large E:
JD December 29, 2012 07:05 PM
Hmm I've always been under the impression that when a RAID controller says it has JBOD it means that it combines all the drives into a single volume.
Even a quick Google yields both explanations from varying sites. Definitely some misinformation going on.
