Old December 23, 2012, 08:53 AM
norfolk's Avatar
Default Redoing a Raid0 on my CrosshairV Formula
Hey guys recently I made the plunge and picked up 2 of these drives here to be Raided on my system,It was a Raid 0.
ADATA S510 120GB 2.5" SATA 6Gb/s Solid Sate Drive (SSD), Read: 550MB/s Write: 510MB/s (AS510S3-120GM-C)
I had one of the drives fail and has since been RMAd but I lost my OS as well.I"m really starting to wonder if going this way is really worth it once I get my new drive back from Adata
Old December 23, 2012, 09:17 AM
dandelioneater's Avatar
I used to do raid 0 for my OS drive (2x 80GB intel ssd's) but I found that it was quite the hassle as well if anything went wrong. Since I was playing games at the time, I decided to break down the Raid array and installed my OS on one of the drives and migrated my steam & Origin folder to the other drive for storage. I liked it this way. Didn't notice any real drop in speed either.
Old December 23, 2012, 09:36 AM
BlueByte's Avatar
Raid 0 won't be worth it if you are using on-board chipset + only 2 drives. do as above stated unless you invest a lot more into your setup.
Old December 23, 2012, 03:31 PM
norfolk's Avatar
Thx dande thats what I was thinking too!!
Not really interested in going anymore in debt for a raid setup so I may just leave the system as is and put steam on the other drive
Old December 23, 2012, 06:54 PM
nasrott's Avatar
Been using raid0 since IBM's biggest harddrive was 80 gig (deathstar we used to call them). Couldn't see myself ever going back to a single OS drive again really. Actually wanna upgrade my 2-120 gig ssd's too 256 gig drives. When ya see the graph on hdtach go into 2000 that is when it is worth it, they test in at 1000mb/s read and write or better in raid0.
Old December 23, 2012, 07:16 PM
BlueByte's Avatar
I run RAID 0 myself, I have a 4 drive right now and have picked up 3 more identical drives on the cheap so will be sporting a 7 drive RAID 0 SSD after xmas some time on a relaxing day. but 2 SSDs in RAID 0 are not worth it with onboard controllers.
Old December 24, 2012, 03:51 AM
nasrott's Avatar
am always up for learning BlueByte why is it you don't like onboard raid controllers, years ago the bus speed was a limit so we used to use a raid card, nowadays is not the case no? 2 drives in raid0 with an onboard controller is fine. Multiple drives on raid 5 or 6 is another level and needs hardware controllers ie: expensive add on cards. Maybe things have changed and am not up to date anymore?
Old December 24, 2012, 06:16 AM
norfolk's Avatar
Geeez I was kinda hoping that the money I spent on this mobo I was getting a controller that I coulod rely on.Really makes you wonder?
Old December 24, 2012, 06:24 AM
nasrott's Avatar
some addon card controllers are more than your motherboard. Honestly don't think you'll have a problem with your onboard controller, raid0 is a hassle to some extent, but in my opinion worth it. Anything that is important too you u back up on external drives. Were talking an OS and some games no? All simply re installed if anything should ever go wrong even from scratch.
Old December 24, 2012, 06:38 AM
norfolk's Avatar
Yep everything that is critical is backed up (Thank goodness) So it was just a reinstall of the OS on my remaining SSD and grab my Steam and stuff off the other drive.
WIP Redoing my rig air to watercool NiteOwl Case Mods, Worklog & Gallery 13 August 16, 2012 12:09 AM
3 SSD 64GB's In Raid0(edit 3 drives In Raid0 results + Pictures) CoolHandL Storage 6 July 23, 2010 11:10 PM
Striker II Formula or Maximus Formula II trayton CPU's and Motherboards 1 August 30, 2009 03:04 PM
FS: Rampage Formula and Striker II Formula MINT! Nademon Buy/Sell & Trade 24 November 24, 2008 11:43 PM
