-   -   Setting up a SSD (http://www.hardwarecanucks.com/forum/storage/58481-setting-up-ssd.html)
pcmike December 11, 2012 02:30 PM
Setting up a SSD
I'm new at this so ..... I am setting up a 256G ssd and I want to copy paste some of my material from my former C drive hhd . Can I do that with windows still installed on the HHD ? I will then format it. My OS will be on the ssd which will be my new c drive. I hope this makes sence . My concern is when booting up the machine will not know which to boot from. I know it's supposed to boot from c but I am not sure.
Thanks for listening, pcmike
Galcobar December 11, 2012 05:10 PM
When installing an operating system to a new hard drive, it's advisable to disconnect any other drives from the system -- this ensures the correct drive is selected, by virtue of being the only choice.
Once you've got the new drive's OS up and running you should have no issues reconnecting the older hard drive and then copying material from it. There are two caveats to that, however. The first is to ensure you're booting off the correct hard drive; this is determined by your BIOS settings. The second is to ensure the material you want to copy isn't in a protected folder under the old OS. If it's just a few files, I find it most convenient to boot up the old hard drive's OS and copy the files into an unprotected folder on the new drive.
elmorejohn46 December 22, 2012 12:41 PM
Yes you can do that just make sure in you Bios that you have the SSD drive as you first drive and when installing windows make sure you are installing it on you SSD dive ,then when it gets though installing ,just copy the files you want on your SSD drive from you other drive.Then on you old drive just go to properties and formatt and then you will have a clean drive to install on.
Generic User #2 December 22, 2012 02:04 PM
is it REALLY that hard to install to the right drive? especially when one drive is full and the other is brand new empty? I can't say I've ever had trouble finding the right drive, and I've never heard of anyone actually installing to the wrong drive (just warnings not to).
gingerbee December 22, 2012 11:40 PM
i would just use cloning software to clone hd to your ssd make sure to use paragon alignment tool then edit your new ssd data and be done
KaptCrunch December 23, 2012 08:15 AM
+1 for sure if current OS has no issues
Arconis is the best for this task
first back-up wanted data, game saves/profiles, pic's etc
then collect all your current OS drivers for motherboard/hardware burn to a disk/or USB stik
update bios/firmware for hardware if need be. before intalling on new drive.
what rest is saying on use one drive to install OS is that making no room for error of install
doing format on a drive that has data on, we all done that some time :shok: formatted a used drive by mistake
