Short SATA cables for MITX systems It's like manufacturers have never seen a MITX system before....getting very tired of wayyy too long cables. I swear my SG07 has a foot-long 24-pin when the port is next to the PSU. anyways, getting to the point, are there any SHORT cables SATA cables with right-angle connectors on one end? stuff in the 4", 6", and 8" categories. |
Akasa makes a SATA cable called the Proslim. The connectors are removable and they can actually be cut down to length. PPCS sells them. No idea if anyone in Canada does though. |
ah, thank you. i found one at ncix once i had the SKU. EDIT: here's the link if anyone else needs it: NCIX.com - Canada's Premier Computer Store - Online PC Discount Store, Buy Computer Accessories I'm sure there must be others selling, but there's one link anyways |
| All times are GMT -7. The time now is 08:35 PM. |
