-   -   Where can I get connectors/supplies to make these sata power cables? (http://www.hardwarecanucks.com/forum/storage/57901-where-can-i-get-connectors-supplies-make-these-sata-power-cables.html)
YoungMan November 15, 2012 01:47 AM
These:
http://img18.imageshack.us/img18/7337/img1606g.jpg
Basically, rather than having my HDDs looking like this:
http://farm7.static.flickr.com/6122/...7762dd1d_z.jpg
I want to make them like this:
http://farm7.static.flickr.com/6026/...72e8d494_z.jpg
NCIX has this:
http://img.ncix.com/images/62819_l.jpg
But it's not a molex power, too short, and only 4 connectors.
So, anyone know where I can buy the molex pins/connectors/cables? I checked monoprice, no luck. Cables are there, but no pins or connectors to crimp yourself.
supaflyx3 November 15, 2012 02:52 AM
Dazmode
YoungMan November 15, 2012 04:28 AM
Cool story bro
Pabz0r545 November 15, 2012 04:55 AM
Really your reply to someone answering your thread is cool story bro?
I don't know if you are troll or not. SHould I tell you or are you going to just cool story bro it?>
JD November 15, 2012 04:56 AM
You are best off making your own though since every case uses slightly different spacing.
I would just buy a molex extension cable, take off 1 end, then push in the SATA power connectors as needed.
Bloodystumps November 15, 2012 08:02 AM
I have a feeling he doesn't know what Dazmode is and being a one word reply he blew it off with "cool story bro" LOL I don't blame him , some times its hard enough getting what you are concentrating on to have to decipher a the meaning of a one word post .
JD has the fix that would be the way I'd do it
enaberif November 15, 2012 08:19 AM
Performance pcs has said stuff as does a lot of other places
Pabz0r545 November 15, 2012 08:47 AM
Ok that makes a lot of sense. And yes JD is right. Most sata power cables can be taken apart and moved up/down the cable if you so desire.
lowfat November 15, 2012 09:13 AM
You don't crimp SATA cables, at least not those kind. You also will not be able to buy them in Canada AFAIK. Performance PCs, Frozen CPU and MDPC-X all sell them. I am going to start to sound like a fanboy here, but honestly the MDPC-X ones much higher quality if you care for that. They are the only company I've found that uses actual Molex brand SATA connectors.
How many do you need and where do you live? If you just need a handful, I can probably give you a bunch of the non-Molex ones since I only use Molex. http://smiliesftw.com/x/embarasseddance.gif
YoungMan November 15, 2012 03:41 PM
Although that's a nice way to put it, it's not entirely true. I googled it and searched the site, but carried nothing I was looking for. So either the guy didn't read my post or didn't check the site. Either way, unhelpful nonetheless.
Thaks dude, but I'm in BC.
Yeah, crimp is probably the wrong word for that. I guess all I need the right angled connectors with the pins inside. Because as JD said, my case has different spacing.
Anyway, going to just buy these cables and take the connectors off them to make my own.
For only $1.65 each when QTY 50+ purchased - 24inch 4pin MOLEX Male to (4) 15pin SATA II Female Power Cable (Net Jacket) | Serial ATA / SATA Power Cables
Seems like the cheapest way to actually get connectors.
