-   -   1tb velociraptor vs wd black (http://www.hardwarecanucks.com/forum/storage/57888-1tb-velociraptor-vs-wd-black.html)
simsin November 14, 2012 01:12 PM
Hey guys,
I always thought the velociraptor drives were interesting alternative but I never considered them until I fell on the following review: Western Digital VelociRaptor 1TB Review | StorageReview.com - Storage Reviews
tell me what are your thoughts on a the topic? I always though the wd BLACK would be best as a main HDD and some ssd would be good to complement.
BeaverBender November 14, 2012 01:25 PM
Meh, I will never go back to platter drives for a main drive... SSD's have spoiled me. 512GB SSD's are already below $400 and below $350 on sale (they will be below $300 shortly), so a 1TB Velociraptor has no appeal for me considering the performance is night and day. I only consider platters for secondary storage when I need at least a few terabytes. The big issue going forward for me will be how the SSD manufacturers solve the declining performance issues as capacity increases.
Bond007 November 14, 2012 01:44 PM
While a velociraptor is faster than a standard drive, an ssd is too much faster to ignore. There may be a select group of people that a velociraptor may suit, but IMO its standard drive or SSD or both (depending if you storage, speed, or both). I wouldn't be able to justify the added cost of a velociraptor knowing that I could get something faster.
simsin November 14, 2012 02:07 PM
what about longevity?
the review says that the velo is better after long term vs ssd which deteriotes after heavy read/writes??
what you think about that?
simsin November 14, 2012 02:32 PM
basically it would be a secondary drive i would have an ssd as a main boot drive
BeaverBender November 14, 2012 02:49 PM
Yes, SSD's do deteriorate in terms of performance over time but there are also tuning methodologies, and these will improve over time.
belgolas November 14, 2012 06:29 PM
It depends on your needs. I would go with an SSD for OS and then a HDD for all the other stuff. I would like a 1TB SSD but none a even close to "cheap."
simsin November 14, 2012 07:13 PM
sop basically a WD black with an SSD is the best bet?
why would the black be better than the velociraptor due simply to size for the cost? (better value)
simsin November 14, 2012 07:32 PM
well needs is best performance for the best price. So SSD main boot drive and common running apps... everything else would be on the secondary drive. so yea.... less applications but I want something very performance oriented!
Generic User #2 November 14, 2012 08:59 PM
you only need a velociraptor for use as a scratch disk. that's pretty much the only workload that can ACTUALLY degrade an SSD in realistic scenarios.
