Old November 11, 2012, 09:11 AM
dandelioneater's Avatar
Default Intel 320 and X-25 G2 together in Raid 0?
As the title suggests, I am thinking of attempting to configure these mismatched drives in Raid 0 on the Z77 chipset. I know they are not the same drive, but I was curious to see if they would work together. The array would be used as a steam directory with the application and games on it so I won't be worried if I lose it.
The speed of the X-25 is 250 read, 70 write & the 320 is 250 read, 90 write. Both drives are sata II.
I guess I'd have to switch the sata controller to RAID in BIOS. I can't recall if that would affect my OS on vertex 3 (AHCI) requiring a reinstall of windows?
Thoughts? Concerns?
Old November 11, 2012, 09:14 AM
lowfat's Avatar
Switching from RAID to ACHI does matter. But if you are not booting from these drives just do a software RAID from within Disk Management. It will honestly perform better anyways.
Old November 11, 2012, 09:19 AM
thanks. I'll give that a try.
Old November 11, 2012, 11:47 AM
well the raid array is up and there doesn't seem to be any issues thus far. Ran crystal disk mark and speeds were about double, which is what I expected. So far so good.
Old November 11, 2012, 01:29 PM
Don't forget to use Intel's SSD toolbox + RST for TRIM support. Or your array is gonna suck balls down the road.
Old November 11, 2012, 03:46 PM
lowfat's Avatar
Since his is just a software RAID his TRIM works perfectly fine.
Old November 11, 2012, 10:43 PM
Oh right, my bad. Not using SSDs as your boot drive is a rare sight for me.
Old November 12, 2012, 08:13 AM
I actually just ran a test to verify that TRIM was working as it should and it is. I installed the latest 11.x RST drivers and ran this test.
Samsung 830 Raid 0 OR Intel 520 Raid 0 Tainger Storage 1 July 2, 2012 06:33 AM
Marvell and Intel Raid conflict Dazmode Troubleshooting 4 January 29, 2012 09:02 PM
Migrating Intel RAID JD Storage 7 March 26, 2011 09:25 PM
SSD RAID support from Intel N.V.M. Storage 8 August 22, 2010 03:05 AM
Intel Raid driver with TRIM; anybody try this yet? chrisk Storage 10 March 21, 2010 12:04 PM
