Old November 1, 2012, 06:19 AM
Default SSDs and SATA1
I am considering a hard drive upgrade to my laptop (Fujitsu P770). Currently there is a WD Black 750Gb drive installed.
Swapping in an SSD should give better performance as well as better battery life and far more shock resistance.
The laptop is used for DJing and video and photo editing. Therefore, space is needed - the smallest I can get away with is 480Gb, with 512Gb being preferred. I may need to install a second SSD in the future as well - which is possible, since the optical drive has been swapped for a second hard drive by (el cheapo from the far east). This works with the P770 - I had two 750Gb drives installed and running at one point, and it worked very well.
The laptop boots both XP and Win7 Ultimate 64bit. I need to keep XP because my DJ software does not run under Vista or Win7.
I am looking at the following:
Intel 520 series 480Gb
Samsung 830 series 512Gb
Samsung 840 series 500Gb
Crucial M4 512Gb
However, the laptop has SATAI (SATA 1). All current SSDs are SATAIII.
Will there be issues with attaching an SATAIII SSD to a SATA1 port (beyond the lack of full performanced, of course!)?
Will XP be able to use the SSD without issue?
Thanks in advance!
Old November 1, 2012, 06:31 AM
supaflyx3's Avatar
Make sure you get an SSD that has its own garbage collection since TRIM isn't supported in XP, and probably isn't supported on your laptops chipset. The SSDs you listed should all work just fine, just be aware that you'll be limited to 150MB/s reads & writes.
Old November 1, 2012, 06:37 AM
TRIM is a function of the chipset? I was not aware of this. Given the age of the P770, I would not expect it to support TRIM in that case....the P770 uses the Mobile Intel QS57 Express chipset. Guess I need to do a bit more research......
Drop in speed is unavoidable, given the SATA1 interface. I was more concerned with compatibility and reliability and low power drain than speed....the upside is that I don't need to buy the latest and greatest and fastest SSD, since the laptop will never see the extra speed!
Old November 1, 2012, 11:27 AM
IRQ Conflict's Avatar
From what I've read TRIM is enabled when AHCI is enabled in the BIOS but the OS has to support it as well.
I want to die peacefully in my sleep, like my grandpa. Not like the passengers in his car, screaming and crying.
Old November 1, 2012, 11:43 AM
BeaverBender's Avatar
In this particular circumstance, I would recommend the Crucial M4 512GB... I've seen it on sale for around $350 lately. I'm too lazy to look up the controller/chipset on that laptop but some of them will clock SATA2 or SATA3 SSD drives down to SATA1 speeds anyway. Even so, you'll still see a good improvement and for DJing I find SSDs mandatory since HDDs have moving parts and that is a recipe for disaster in the literally fast-moving DJ business.
Creationists make it sound like a ‘theory’ is something you dreamt up after being drunk all night — Isaac Asimov
All thinking men are atheists — Ernest Hemingway
Faith means not wanting to know what is true — Friedrich Nietzsche
Old November 1, 2012, 01:00 PM
Soultribunal's Avatar
I would suggest something that has a solid ITGC or even since the Computer is more legacy than anything else a Crucial V4 would fit the bill for you. And its cost is probably better than the higher performing items.
-ST
Old November 2, 2012, 06:37 AM
Thanks to those who have suggested the Crucial M4. My research seems to indicate that this drive, the Samsung 830, and the Muskin Chronos Deluxe are about the most reliable on the market.
Some newer drives, such as the Intel 520 and the Samsung 840, may be as good but they are either much more expensive (in $$ as well as $/Gb) or too new to know.
NCIX has a REALLY good price on the Mushkin Chronos Deluxe 480Gb just now. Might need to go for a drive at lunchtime.....
From what I have read about the Intel Mobile QS57 chipset, TRIM is not enabled. There was a BIOS upgrade that did support TRIM, but that BIOS was never offically released by Intel.
Therefore, there seems to be three things needed for TRIM:
Chipset support
AHCI enabled
OS support
I have two of the three when running Win7, and one of the three when running XP, on the Fujitsu P770 laptop. Guess that will have to do.....
This also means that garbage collection efficiency - it is can be determined should be part of my selection criteria.
Old November 2, 2012, 11:26 AM
SInce you need good ITGC, the V4 or the Chronos were what was recommended to me on an XP system.
-ST
Old November 2, 2012, 11:41 AM
Picked up a 480Gb Chronos at lunchtime today, from NCIX Mississauga.
I asked about the drive's reliability, and the clerk stated that they had never had one returned as far as he know. About what I have read elsewhere for the most part.
Now the fun part, backup up the stuff that is not going onto the drive (it is replacing a 750Gb WD Black), then getting the OS and important stuff moved over.
Acronis, here I come!
Old November 2, 2012, 06:08 PM
Perineum's Avatar
Just make sure it's a newer version of Acronis. Acronis from 2011 will not set up your SSD with the proper 4K alignment. Verify if your alignment is okay with AS SSD.
2 SSDs Arinoth Price Check 3 July 8, 2012 10:00 AM
Is there an Advantage to one of these SSDs? ValueDriven Storage 2 February 21, 2012 09:40 AM
SSDs?! h0w3r LinusTechTips Q&A 1 November 18, 2011 10:07 AM
AMD and SSDs Borg Storage 14 June 19, 2011 01:03 PM
Need Help with SSDs! revixd Storage 21 January 11, 2010 03:45 PM
