-   -   RevoDrive 3 240GB vs 2x 120gb SSD in Raid 0 (http://www.hardwarecanucks.com/forum/storage/57222-revodrive-3-240gb-vs-2x-120gb-ssd-raid-0-a.html)
bigFOIG October 11, 2012 10:24 PM
Which one is faster? Do you suggest getting the RevoDrive at all? Any opinions appreciated. Thanks!
Squeetard October 12, 2012 08:13 AM
I'd get the Revodrive X2. PCI-E and no problems with Trim. And 1.5gbs max read!
JD October 12, 2012 01:43 PM
I have the RevoDrive3 X2 480GB (the one which was reviewed here). I see over 500MB/s read/write in CrystalDiskMark with it under Windows 8.
Windows 8 thankfully didn't need any drivers for it, but it still does rape the boot time since it has it's own BIOS to initalize. Windows 7 does require drivers for it to show up though.
Likewise, I cannot install Windows with it plugged in, not sure why. No biggie though since I don't use it for my OS.
I suspect 2 SATA3 SSD's would be faster than it though. A single 256GB SSD should actually be sufficient too. They are faster than their 128GB counterparts.
3.0charlie October 12, 2012 02:23 PM
Yup, same here - using a Revo 3 240Gb. If I'd do it over again, Raid 0 SSDs would get my choice.
bigFOIG October 12, 2012 04:07 PM
So is this what you guys are saying?
RevoDrive 3 X2 > 2x 120gb SSD in Raid 0 > RevoDrive 3?
gingerbee October 12, 2012 04:12 PM
i have had all 3 and i know run ssd's 120 vertex 3 in raid cause i use raid too much for data storage too so i gave up the revo that and i found all around i get higher read and write with raid then i did with the revo's my2cents and i didn't use software i am just talking about daily use as in load times adn boot times for everything
