Old October 11, 2012, 12:02 PM
Default RAID/HD Options
Alright here is my situation and current setup. I currently have (2) 2TB WD Black Drives in a RAID 1 setup for all of my computer storage. These drives are used for storage/games, since my primary SSD is only 60GB and as you all know does not hold much more than the OS and a few apps. Since these drives were not just used primarily for storage, I wanted the 7200RPM for the increased performance. I also have a 1TB Black drive (it was an unused older drive) that runs a weekly backup on my important drives... yes I am a bit cautious when it comes to my data.
Now I am running out of space quickly - I am looking at current options, with obviously a limited amount of cost in mind. Since I have already purchased these drives and to limit cost I see these options as possibilities.
- Drop the RAID and gain an additional 2TB Space (will keep me for short term and cheapest option)
- Purchase a 256GB SSD, and then purchase a few extra WD 3TB Greens for my storage, since I don't need the 7200RPM anymore (Obviously most expensive option)
- Keep my current setup as is, and build a separate storage box with some new HD's (expensive again, but a fun project. I have no experience with this type of thing though)
I am tempted to do option (2) because it gives me more of a long-term solution... but since I already own the blacks this seems a bit foolish. Option 1 seems like a very quick option for the short term.
My main concern right now is losing the data when I drop the drives out of RAID As I haven't done this before, will it lost any data or will it create (2) separate partitions on each hard-drive? I can't lose any data, because I hold a lot of work related information. I also would have trouble (if it will wipe the data out when I drop the RAID) to back this up onto anything else since I have about 1.9TB of data.
Anyway, just looking for options/opinions on the matter. If I haven't been detailed enough or if you have any questions, let me know.
Thanks in advance.
Edit: Sorry about the formatting :)
Old October 11, 2012, 01:27 PM
sswilson's Avatar
You might want to go back and clean up your links. The formatting you're trying to use doesn't work on this website.
single raid array on two raid controllers scottyhouse Storage 2 September 15, 2012 08:35 AM
Samsung 830 Raid 0 OR Intel 520 Raid 0 Tainger Storage 1 July 2, 2012 06:33 AM
Other options than WD ? botat29 Storage 18 February 23, 2012 11:49 PM
RMA: What are my options? Gaston Troubleshooting 7 March 22, 2010 12:34 AM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
