Old October 3, 2012, 09:38 AM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
The drive is 4K aligned...AS-SSD shows that via its green numbers.
Personally....I would backup my data sani-erase the drive and test it on a DIFFERENT rig as a D drive. See what the numbers come back. If they are good. Bonus. If not leave it for a day plugged in. Then do another sani-erase (you might have hit your daily limit for writes and then the SF2281 started throttling). See if its good now. IF it is....bonus. If not, time to talk to Corsair about a RMA.
IF it does come back good. Reinstall in the first rig as D drive. Update to the latest Intel RST drivers. Run ONE test (say CDM). If its good...bonus. Reinstall the os on it and go about your life. If its not good. Try a known good SATA cable. Redo the test. if still crap...try a dif port. IF its still not good. Something at the mobo controller level is causing issues. Check for latest bios driver update. If none exist...your screwed.
Best guess its either a driver issue, a bad cable...or ONFi 1 NAND strikes again and its a drive on its way out.
Old October 3, 2012, 11:38 AM
Alpine's Avatar
I have a new Patriot Wildfire 120GB sata 6GB still unopened. Im gonna install windose on it using the same sata connection on the MB.
But the same time, i will swap the corsair SSD into my second PC to test it.
Ill post news later on that.
• ► ›Main system
• ► › |I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
• ► ›Server system
• ► › |I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
Old October 3, 2012, 04:34 PM
Alpine's Avatar
with firmware updated to version 5.3.
using another 6gb/s cable and the result is:
• ► ›Main system
• ► ›Server system
Old October 3, 2012, 05:19 PM
Alpine's Avatar
here with my Patriot Wildfire SSD with a new windoze install...
• ► ›Main system
• ► ›Server system
Old October 3, 2012, 06:28 PM
AkG's Avatar
First thing the corsair reps are going to do is make you do an ATTO test. run it and lets see what the power curves look like. :)
Did you do a sanitary erase?
Old October 3, 2012, 08:34 PM
Alpine's Avatar
i didn't have do anything yep with the corsair ssd. I still need to make a backup ffrom that drive.
• ► ›Main system
• ► ›Server system
Could a hardware problem cause a driver problem? LaughingCrow Troubleshooting 4 January 19, 2012 11:46 AM
Steam connection problem (Problem Fixed) great_big_abyss Gaming 3 January 10, 2012 05:37 PM
Hard drive problem or Windows 7 Problem?! aeminence New Builds 4 October 13, 2011 06:46 AM
HD Speed Nerdy Storage 6 December 30, 2010 05:34 PM
could this be a game problem or a video driver problem? Shadowmeph Troubleshooting 4 December 17, 2010 07:01 AM
