Old September 19, 2012, 05:02 PM
Most SSD's sold these days include a 3.5" drive adapter in the box, unless you purchase an OEM drive. Most firmware updates are fine so long as they are non-destructible ( many of OCZ's latest have been destructible), make sure to read up on the update that you are applying to your specific drive, as methods may vary. Bootable CD's are an easy way to perform the task, however you may just luck out and have the latest firmware installed out of the box.
Old September 19, 2012, 05:19 PM
great_big_abyss's Avatar
Actually one of the drive cages on your 690 should have holes to accept a 2.5" drive
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old September 19, 2012, 05:43 PM
zeus3dfx
Guest
Posts: n/a
Hmm, on the original 690? I'll have to take another look at it.
Also, do you guys think I should stick with an 128GB version?
And what do you think of the Plextor M5S?
Old September 19, 2012, 07:45 PM
Plextors M5S looks to be a good drive:
http://www.google.ca/url?sa=t&rct=j&...EnyUoJFCt8BBcQ
A 120-128GB drive will leave you with @111GB after formatting, and they can start to feel quite small after installing apps and a few games. If that is all that you require, then there is no real reason to get a larger capacity, although for best performance it is usually recommended to use less than half of the drives capacity. I run mine at nearly 75% full, and they seem just fine though.
Old September 20, 2012, 06:46 AM
Soultribunal's Avatar
Originally Posted by zeus3dfx View Post
How do I go about updating the firmware on an SSD before installing Windows on it?
Also, I realized just now that a 2.5" to 3.5" kit would be VERY helpful, as my cm690 has no space for 2.5" drives. Do any of the drives we talked about come with a kit?
Well if you want something cheap, reliable, good ITGC, comes with that adaptor and is under $100.
Mushkin Chronos 120GB 2.5IN SATA3 SandForce SF-2281 SSD Solid State Disk Flash Drive
Recommended to me by a good friend on the forums. Sometimes its best to take a cheap foray into the SSD world first before dropping 2bills on a drive.
Just image with Acronis and you're laughing,
-ST
Suggestions for my network setup sakage.shinga Networking 4 January 27, 2012 04:07 PM
Dual monitor setup suggestions rawrjau Display Units 1 September 11, 2011 10:42 PM
Need suggestions on a Modular PSU for a WHS setup Shftup Power Supplies 5 September 29, 2010 09:34 PM
Corsair Obsidian WC setup, suggestions? Z Overlord Water Cooling 36 October 6, 2009 10:21 AM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
