-   -   missing space on my ssd? (http://www.hardwarecanucks.com/forum/storage/56459-missing-space-my-ssd.html)
Goon3d September 1, 2012 06:09 AM
I already disable file paging and turned hibernate off, I wonder where this space is hiding?
http://i84.photobucket.com/albums/k28/kapow1/disk.jpg
enaberif September 1, 2012 08:06 AM
http://www.jam-software.com/treesize...download.shtml
BryceBooth September 1, 2012 11:05 AM
What space are you looking for? A formatted 120 SSD works out to 111 GB. Have you installed any apps, or games?
Some other graphical software to view data; WinDirStat, Disktective
ipaine September 1, 2012 11:17 AM
Considering you have windows 7 on that machine it doesn't look like you are missing anything. The standard size your ssd will be after formatting would be 111GB as mentioned above.
That said the Tree Size program that enaberif mentioned is very good for finding where space is being used.
Master_Shake_ September 1, 2012 11:50 AM
is system restore on?
that will take some space.
Goon3d September 1, 2012 12:48 PM
Thank you all for the reply.
I don't know if I'm reading this http://i84.photobucket.com/albums/k28/kapow1/disk.jpg properly but I think I'm missing some 2 to 8 gigs of space?
JOHNYBROKE September 1, 2012 02:05 PM
If its your primary some space is set aside no?
Goon3d September 1, 2012 06:38 PM
I think I just found the missing space;
http://i84.photobucket.com/albums/k28/kapow1/disk2.jpg
Insomnia9669 September 2, 2012 09:26 PM
You could use a program called SpaceSniffer link . It will show you everything you have on the drive and there sizes etc.
binaryman September 5, 2012 01:55 PM
Run Directory Report in administrator mode
Directory printer, find duplicate files, rename files, show folder size, and maintain your files - all in 1 tool
That way it can find hidden files
