Originally Posted by EmptyMellon Even if you were to go with an low capacity HDD (250GB or 320GB), you will have room to spare and save some cash. Your call. |
That certainly sounds reasonable, and later when your budget allows for an SSD upgrade you can always use the drive for storage or backups. Both Windows 7 & 8 support TRIM, and although SSD's slow down over time they are still worth it due to their performance. After formatting a 120 GB SSD, you'll have approximately 111GB available which is plenty for the OS, a bunch of apps, and a handful of games.
SSD's and hard drives can both fail at the absolute worst time, whether it's a firmware issue, or the dreaded head crash. Whatever you decide to choose, backup your valuable data. If you get an SSD, don't be afraid to use it, even with a lot of writes it should last at least a couple of years. It may be worth your while to browse the forums here, as well as thessdreview.com
